Omega Help Area => Omega General Help => Topic started by: andy_driver on 22 March 2010, 12:15:08
would anyone know the easiest way to identify which diff i have if its a limited slip diff or a non limited slip diff type cause reason i am asking is that when i switch the traction control off both wheels spin oh and the diff sounds like a bag of bolts as i need one badly .
its 95 96 2.5 cdx manual .
any help would be greatfull .
thanks
two easiest ways :-
filling plug should have a plastic bung in it with German wording for "LSD oil only"
if you slowly start moving on full lock in 1st, there'll be a kind of shh shh shh shh noise coming from the rear (window open) as the tyres load and unload
thanks for the reply eh there is no plastic bung :( in the filling plug a will try what said on full lock . oh a ment to say the haynes manual showes there is an ID tag on the diff but i dont have one of them either :( lol . do you know if i can buy a rebulid kit to replace the bearings in the diff .
thanks
It will only be an LSD if its been swapped.....and sadly, I am yet to see an LSD with the palstic bung either.
The only fool proof way is to pop the back plate off and look at the internals
well judging with the noise its making its the original 170.000miles :D if i think right the back plate has got the abs sensors on it and has got a mount on it
it's possible to rebuild the diff - i've done five or six.
the bearings aren't cheap tho. the crownwheel carrier support bearings are about £90 each and GM-only.
you can just take a driveshaft out and have a look in the side. two-pin means open diff, four-pin means LSD.
for what it's worth, I reckon about half of the LSDs still have the plastic bung.
thanks for the info certainly isnt cheap thow lol .
my god i tryd getting the shafts out of the diff before there a nightmare i mean there solid didnt budge lol
