Omega Help Area => Omega General Help => Topic started by: nonames on 08 April 2010, 16:21:59
Title: Prop shaft centre bearing question
Post by: nonames on 08 April 2010, 16:21:59
I need to replace the centre bearing before it breaks completely
is the 2.2 diesel prop shaft the same length/size as the 2.2 petrol, also is it recommended to replace the whole prop inc bearing or just the bearing alone
any help would be great :)
Title: Re: Prop shaft centre bearing question
Post by: feeutfo on 11 April 2010, 06:45:33
bumped for replys from page 4
Post by: Omegatoy on 11 April 2010, 08:52:27
last time i bought one it was a matter of seperating the two halves, then driving off the old one and replacing with the new, total time including removal and replacement was just over 2 hours, it comes with the rubber support, done two or three and never had to do them again, do  mark on the two halves tho so it is in the same alignment when put back together,
you will need a good quality vice though on a strong bench!!
