Omega Help Area => Omega General Help => Topic started by: GLENNY BOY on 01 May 2010, 16:02:42
Title: climate control blowing hot all the time
Post by: GLENNY BOY on 01 May 2010, 16:02:42
hi all every time i put the climate conrol on i set it on low it still blows out warm/hot air. has it happened to anybody else ? has anybody got any ideas why this is happening thanks :y
Title: Re: climate control blowing hot all the time
Post by: Welung666 on 01 May 2010, 17:13:24
Bertie has the same problem, hopefully he's coming over to me tomorrow for us to investigate. I'll let you know the outcome :y
Post by: GLENNY BOY on 01 May 2010, 17:59:38
thanks :y
Post by: dbug on 01 May 2010, 18:02:06
Needs regassing?
Post by: GLENNY BOY on 01 May 2010, 18:04:22
i dont know does mine have a/c ???
Post by: cmeonthemove on 01 May 2010, 18:09:48
If it's a CDX then yes. Is it blowing 'hot' air as in if you have the heaters turned right up, or just like you haven't got the air-con on? I'm guessing it's blowing air at ambient temp which suggests you need the system regassed, but get it done by a proper aircon technician as they can pressure check for leaks and vacuum out the system too.
Also check your coolant level as too low coolant will stop the condenser kicking in as I understand.
Post by: GLENNY BOY on 01 May 2010, 18:13:37
yes its warm /hot air even set on low and even with climate control off it feels hot in the car :y
