Omega Help Area => Omega General Help => Topic started by: macca on 03 May 2010, 13:02:24
Title: oil in plug well
Post by: macca on 03 May 2010, 13:02:24
Hi,
While investigating the source of a coolant leak from the back of the engine area, i pulled the front HT lead off to find it covered in oil(3.0 mini facelift). Does this indicate a cam cover gasket failure? or something else?
thanks
mark
Title: Re: oil in plug well
Post by: Andy B on 03 May 2010, 13:16:16
Hi,
thanks
mark
yes.  :(
I've just done the very same thing. Just about finished my cam belt from Saturday ... we were out all day yesterday - Honest!  :y and thought I'd pull no 1 plug lead to have a look   :'( Wet through with oil. So was no 3 but not as much  :'(
hey ho!  :-? :-?
Post by: Ghost on 03 May 2010, 14:09:47
Oil in plug wells is a sign of rocker gasket.
an easy way to get the oil out of the plug wells is to use a syringe, the type for refilling your ink cartrige on the printer are good.
you will need to put a straw on the front ie from a wd40 can fits great,  its an easy way to get the oil out and saves a bit of money.
Post by: OmegaGav on 03 May 2010, 16:19:54
I used rolled kitchen roll  :y :y ;)
Post by: OmegaGav on 03 May 2010, 16:26:49
Hi,
thanks
mark
Think you found 2 of the most common problems on the omega  :-[
1 the starship enterprise failure (HBV) ::)
2 cam cover gasket failure :-[
but you're in the right place, check maintence guides :y
Post by: Kev_B on 03 May 2010, 16:35:30
I used a Cif trigger-spray thing, put the tube right down into the well, and squirted it into a Pot Noodle tub...   :)   After eating the Pot Noodle of course...   ::)
Post by: OmegaGav on 03 May 2010, 17:07:22
I hope it was beef & tomato, with heinz ketchup. not that awful sachet stuff  ;D ;D ;D
Post by: Smooth on 03 May 2010, 20:26:09
Small shryinge does the trick then use vx rocker gaskets :y
Post by: Zuffenhausen on 03 May 2010, 22:51:41
We used Elite Pete, completely hassle free.   ;D ;D
Post by: des on 04 May 2010, 10:47:25
Take it vx gasket means gen one.s
just done mine (none gen) still leaking :(
Bugger  >:(
Post by: tunnie on 04 May 2010, 10:54:33
Bugger  >:(
Yup Geniune Vx gaskets only, black sealant, and torque covers to 8Nm and will last a long time!
Pattern ones are rubbish
Post by: henryd on 04 May 2010, 11:42:18
and probably be good to clean the breathers at the same time :y
Post by: ScaniaV8 on 04 May 2010, 14:13:01
As Henry suggests...it would be good to clean the breathers as well otherwise it's just false economy and likely to be blowing the gaskets again with resultant oil leakage.
