Omega Help Area => Omega General Help => Topic started by: I_want_an_Omega on 11 May 2010, 10:14:03
Title: Door strap problems ....
Post by: I_want_an_Omega on 11 May 2010, 10:14:03
Hi,
I know that there is a fair bit on the site about fixing door straps - but this focusses on where the straps attach to the body. Either replacement washers or re-inforcing plates.
Mine seem well fixed at those points - the bit that goes into the door seems to be the problem. I cant seem to find anything about fixing that as a problem.
Any ideas?
Thanks ........... Rob
Title: Re: Door strap problems ....
Post by: Andy B on 11 May 2010, 10:27:07
Hi,
Any ideas?
The reinforcing plates are for the inside of the front of the door. If you have problems with the A post fixing point, then it'll need welding.  :y
Post by: Welung666 on 11 May 2010, 10:36:12
Hi,
Any ideas?
Spot on :y I've welded a few now.
Post by: I_want_an_Omega on 11 May 2010, 11:01:33
Thanks - thats clearer now ........
Post by: kcl on 11 May 2010, 11:55:14
I need to repair the fixing on the A-pillar but do not have welding equipment on-hand. WOuld it be possible to drill holes through the spot weldings and put a flat headed bolt through the hole and put a nut on it from the inside?
