Omega Help Area => Omega General Help => Topic started by: ernst on 08 May 2010, 13:50:31
Title: oil around diff
Post by: ernst on 08 May 2010, 13:50:31
hi,seem to have a bit of oil around the diff :(,its not noisy when driving,is this comon,i assume its an oil seal leak are they easy fixed :question
Title: Re: oil around diff
Post by: biggriffin on 08 May 2010, 14:17:59
if its on the front of the diff or the sides the seals my just be weeping, easy option check the level and top it up,
Post by: Jimbob on 08 May 2010, 16:25:32
http://www.omegaowners.com/forum/YaBB.pl?num=1157722402
may help, and for reference, check the index in the maint guide section  :y
Post by: ernst on 09 May 2010, 14:58:48
thanks for the info will have a go when ime of work in summer :y
Post by: Matchless on 10 May 2010, 12:51:51
The guide is for a pinion shaft seal. If it is an output shaft seal leaking then its easier to fix.
Just unbolt the drive shaft from the back of the hub and swing it clear.
Use a tyre lever / pair of LARGE screwdrivers etc to pop the drive shaft out of the diff (its held in with a spring ring)
Prise out the old seal and fit the new one.
Reassembly is the reverse etc etc.
Post by: ernst on 11 May 2010, 19:56:42
hi,thanks for that,its proberbly an easier  fix will have to power wash it and then see were its coming from,thanks again. :y
