Omega Help Area => Omega General Help => Topic started by: guyvaux on 15 May 2010, 13:36:29
Title: misfire
Post by: guyvaux on 15 May 2010, 13:36:29
I have a general misfire on my 3.0 V6. Seems to be worse on kickdown or in sport mode. any ideas?
thanks in advance
Title: Re: misfire
Post by: tunnie on 15 May 2010, 13:39:36
take plug leads out, any oil in there?
Title: Re: misfire
Post by: guyvaux on 15 May 2010, 14:49:24
Just checked them all....oil free!
Title: Re: misfire
Post by: tunnie on 15 May 2010, 14:51:43
couple of things to try:
1) unplug the MAF sensor, does that help?
2) Age / miles of plugs?
3) Do a paperclip test  :y
Title: Re: misfire
Post by: guyvaux on 15 May 2010, 15:00:38
Going to try that now...will let you know asap...
Title: Re: misfire
Post by: guyvaux on 15 May 2010, 15:12:04
Got the codes 73 and 13
Title: Re: misfire
Post by: tunnie on 15 May 2010, 15:15:34
73 is MAF, was it unplugged when you did the test? If not unplug it now and take it for a spin
Title: Re: misfire
Post by: guyvaux on 15 May 2010, 15:17:11
Unplugged MAF and it ran worse.
Plugged it back in to do test.
Title: Re: misfire
Post by: guyvaux on 15 May 2010, 15:29:59
Unplugged MAF and took for a spin - misfire a lot worse...
Title: Re: misfire
Post by: Varche on 15 May 2010, 15:33:07
Hi. I have got my spark plugs out at the moment hunting down my misfire. Very similar sounding to yours but mine goes after 4 miles or so.
A few years back, I had something very similar and after changing the plugs and leads it was still there and it turned out to be the DIS pack down the back of the engine.
Title: Re: misfire
Post by: guyvaux on 15 May 2010, 15:37:19
Mine stays all the time. Did only start today though. Hoping it is not the DIS pack! Mainly happens when pulling off quickly or using kickdown.
Title: Re: misfire
Post by: guyvaux on 22 May 2010, 15:17:52
Still no improvement. Seems worse in this hotter weather though....Any ideas?  :-/
Title: Re: misfire
Post by: guyvaux on 25 May 2010, 23:56:30
Going to change plugs when I get chance, see if that helps.
Any other ideas/theories welcome!
Thanks
