Omega Help Area => Omega General Help => Topic started by: olliejm on 28 May 2010, 10:15:12
Title: Facelift foglight bulbs
Post by: olliejm on 28 May 2010, 10:15:12
Hi all
Can anyone tell me how to replace a foglight bulb on a facelift omega?
It doesn't tell me in the online manual - do I have to remove the bumper?
Any help will be very much appreciated.
Cheers
Ollie
Title: Re: Facelift foglight bulbs
Post by: TheBoy on 28 May 2010, 10:21:28
I reckon it would certainly be easier to remove bumper.  Only takes 5 mins to remove it anyway...
Post by: harpersimon on 28 May 2010, 12:17:23
Just read this... Seriously!! You have to remove the bumper to replace fog light bulbs?!!!
Post by: bert on 28 May 2010, 12:23:49
hi i replaced a broken foglight did not remove bumper just unscrewed grill next to foglight them unscrewed the light
Post by: TheBoy on 28 May 2010, 15:55:59
Probably not, but I'd bet its a damn sight easier, esp the first time you do it, so you can see what to do.  Bumper comes off in less than 5mins, dead easy.
Post by: olliejm on 28 May 2010, 16:02:14
Cheers again everybody - I'm going to give it a go now.
Hopefully won't need to start new post entitled 'HELP - How do I put a bumper back on!!'.
That's the only downside, that I've found to owning an Omega - no instruction on how to do this. Haynes is absolutely useless - as I'm sure you all know already.
Thanks again - this is, without equal, the most helpful site I've ever been - a credit to everyone.
Ollie
Post by: TheBoy on 28 May 2010, 16:05:27
2 screws each side securing bumper to wheelarch (on facelifts, the lower screw is up from underneath).
1 screw near each headlight
2 (3 on facelift) clips underneath holding bumper to subframe.
When to pull forward to withdraw, unplug fogs and temp sensor - one plug for each (1 plug for all on facelift)
Refit, in true haynes style, is reverse method ;D
Post by: olliejm on 28 May 2010, 16:14:29
Thanks - really helpful cheers
Ollie
Post by: VXL V6 on 28 May 2010, 22:30:19
Nah, you can change the facelift foglight bulbs without dropping the bumper.
Just reach up to them from underneath. 1/4 turn and the bulb pulls out.  :y
Post by: tidla on 28 May 2010, 22:34:52
that sounds more like it :y
Post by: olliejm on 29 May 2010, 11:45:32
That makes much more sense - I'm having a problem undoing the hex screws.
Bulb changes should be much easier than dropping bumper.
In the online manual it mentions foglights but not how to replace a bulb.
Thanks for that
