Omega Help Area => Omega General Help => Topic started by: eliteomegaman on 29 May 2010, 09:47:44
After all the problems i've had & now fixed, a new problem has now emerged! The font o/s door pin won't budge - can use the central locking which opens all 3 doors but then i have to use the key to open drivers door but the pin won't pop up although the door opens! To lock the doors, i have to use the key manually as 3 doors engage shut but immediately the pins pop back up >:(
Don't know if its the motor or solenoid or maybe the motor is the solenoid :-/ (i'mconfused.com!!)
Can anyone tell me how to fix it & if it's a tricky job for a novice :-?
Just read the entry from ImpactPete about the same problem!
Thanks to the reply by bodach i will try the old 'WD40' trick & keep my fingers crossed that i have the same luck as he had :y
