Omega Help Area => Omega General Help => Topic started by: poohbear on 29 May 2010, 21:22:12
hi i`m new to this, but has any one had this message on the dash "Low beam Fld/vision" all bulbs are working also it came on when light were off.
Also a rubber pipe on the egr pipe on the side of the engine keeps blowing any ideas?
hi i`m new to this, but has any one had this message on the dash "Low beam Fld/vision" all bulbs are working also it came on when light were off. .....
you ideally need your car tested with a fault code reader. There's a level sensor on the front near side wishbone & the same on the rear near side radius arm, it could be either of these or the level motor in either of your headlights.
Welcome to the forum! :y :y ;)
many thanks will get it looked at after the jollies :)
The egr has a stainless steel corrugated pipe to connect it to the exhaust manifold. If yours has a bit of rubber pipe on it then it has been bodged.
