Omega Help Area => Omega General Help => Topic started by: JamesV6CDX on 29 May 2010, 11:27:31
Title: Petrol pipes. Which way round?
Post by: JamesV6CDX on 29 May 2010, 11:27:31
Hi Guys
As you look into the top of the petrol pump, in the boot - which way around do the pipes go - feed and return?
Which side is the feed, as you look at it from the rear - driver or passenger?
Thanks all  :y
Title: Re: Petrol pipes. Which way round?
Post by: JamesV6CDX on 29 May 2010, 12:48:35
If  anyone would be able to check, I would be ever so grateful ;)
Post by: Welung666 on 29 May 2010, 12:55:48
As you look from the rear of the car you should have the plug closest to you. Look closely through the dirt on the plate and you'll see an S and R stamped next to each pipe. IIRC S is left and R is right :y
Post by: JamesV6CDX on 29 May 2010, 12:56:40
A pint for that man!
Post by: JamesV6CDX on 29 May 2010, 12:57:31
Ah hang on... which one does the feed pipe connect to?  ::)
Post by: Welung666 on 29 May 2010, 12:58:18
;D ;D ;D err 'supply' and 'return'! ;)
Post by: JamesV6CDX on 29 May 2010, 13:00:24
DURRRRRRRRRRR!!!!!
*slaps myself*
;D
Post by: tidla on 29 May 2010, 13:37:27
and a dime bar for yourself. ::)
Post by: JamesV6CDX on 29 May 2010, 13:41:35
DIIIIME Bar!  ;D
Post by: Agemo on 29 May 2010, 22:33:56
No marks on my Turbo Weasel pipes, but I have colour coded them for "next time".  ::)
