Omega Help Area => Omega General Help => Topic started by: Sir Tigger KC on 31 May 2010, 20:00:03
Title: Fans not coming on properly
Post by: Sir Tigger KC on 31 May 2010, 20:00:03
After abit of a run yesterday, I stopped at the shop and was in and out.  Got back in turned the ignition on and the temp was at 100!! :o :o I could hear the fans running so started up and sure enough the temp dropped back so headed home.
When I got home I turned the engine off and could hear fans running, but when I turned the ignition off the fans stopped, when I popped the bonnet I saw that it was only the fan at the rear running and not the two at the front!
Any ideas peeps?
Title: Re: Fans not coming on properly
Post by: same #same# on 31 May 2010, 20:03:15
sounds about right if all fans going can flatten the battery as draining just to cool down rad.
Post by: dbug on 31 May 2010, 20:47:12
Font two are for air con
Post by: Andy B on 31 May 2010, 21:00:16
pretty sure it's the single rear fan for aircon. The front two can run slow or fast which would suggest that they're both for engine cooling.
Post by: Richgm on 31 May 2010, 21:27:39
My front 2 don't run if the aircon is off
Post by: Andy B on 31 May 2010, 21:43:40
it could always be me that's wrong ..... again ::) :y
Post by: Sir Tigger KC on 01 June 2010, 09:54:09
Until recently, all three fans worked.  Now its just the rear fan working and only when the ignition is on.  :(
So when I turn off after a run there's nothing cooling the rad and its getting hot!!  :o Its a new rad and I don't want it to go pop!!!  >:(
I've checked the fuses and all good, could it be a dodgy relay?
