Omega Help Area => Omega General Help => Topic started by: Vamps on 12 June 2010, 21:23:03
Title: Door lock button
Post by: Vamps on 12 June 2010, 21:23:03
Apparently  it opens on the 'blip' (so solenoid must be working) but will not lock, need to use the key. I seem to recall this problem before and I am sure I just put a bit of wd40 around the button :-/ :-/ :-/
Any other idea's......
Title: Re: Door lock button
Post by: dbug on 13 June 2010, 01:52:36
Swap the solenoid
Post by: sjc on 13 June 2010, 11:43:41
Could be sticky mechanism
Try removing the door catch assembly to clean and re-grease all the various levers and spindles, or simply remove the door card and give it a good blast with silicon grease spray.
I suspect you will end up replacing the solenoid in the end anyway but might be worth a go.
Post by: Lizzie_Zoom on 13 June 2010, 12:14:57
Yep, that is what I had to do eventually. although I am not sure about a non-Omega has you have Mike! :y :y
Post by: sjc on 13 June 2010, 12:42:29
...or simply remove the door card and give it a good blast with silicon grease spray.
BTW, give the door lock/catch assembly a good spray, not the door card!  Just though I better get in first!
Parts probably came out of the same factory anyway  :D
Post by: cam2502 on 13 June 2010, 13:13:08
i have the same problem......bloody annoying >:(
Post by: Vamps on 14 June 2010, 22:32:08
We have an Omega, an estate actually... :P :P
The problem is with a car I was going to buy, an Omega, I said the solenoid, they are not offering to repair, this and a couple of other niggles has put me off it to be honest, it was top money as well, and it if a facelift, not sure I like them.... ::) ::) ::)
Post by: Lizzie_Zoom on 15 June 2010, 07:45:51
Sorry Mike, misread your profile details for some reason :-[ :-[ :-[
......and I go to Specsavers!! ::) ::) :D
