Omega Help Area => Omega General Help => Topic started by: markspark on 28 May 2010, 13:44:23
Title: 2.5 TD tractor pump help
Post by: markspark on 28 May 2010, 13:44:23
Hi guys and gals as above i have a 2.5 tractor and the diesel pump is leaking fuel from a block with a pipe going to it thats about 2" sq its mounted on the side of the pump with 4 screws/small bolts what im looking for is to buy a new seal do you know where these can be bought from i have tried VX and a couple of companies that repair pumps with no joy
also what is the part and whats its use
TIA
Title: Re: 2.5 TD tractor pump help
Post by: Omegatoy on 28 May 2010, 17:07:37
any good bosch diesel centre should be ale to get the seal/gasket/Oring you require :y
Post by: markspark on 28 May 2010, 17:13:14
im being told that you have to buy pump part at around the £300 mark
Post by: markspark on 28 May 2010, 17:24:42
here is a picture of the part on my pump that is leaking it leaks where the black thing meats the pump
(http://i585.photobucket.com/albums/ss293/markspark71/25tdpump1.jpg)
this picture is not mine its one i have borrowed off an ebay listing hope the seller don't mind  ;D
Post by: hoofing it on 28 May 2010, 18:12:56
the black box bit is the throttle control + cable.
unbolt it and slowly pull it way from pump body enough to put instant gasket(blue hylomar) around the flange and tighten back up this is a short term fix.
also check the plate on top of the pump above the black box these tend to leak :y
ive got a pump waiting to be fitted i'll try and get some photo's on tommorow :y
Post by: markspark on 28 May 2010, 18:17:23
photos would help my engine is very dirty ive only just bought this car and not had the time to clean the engine yet it is leaking oil from somewhere at the front high up not sure where untill i clean it off as the fan has splattered it everywhere
when is your pump being fitted and whats wrong with the old pump
Post by: hoofing it on 28 May 2010, 18:47:05
The oil is coming from the pipe above the rad that says turbo diesel it's split :y
I'm fitting the pump myself as fault code 64 won't clear it's been diesel magiced about 7 times.
i'd recomend you change the oil+filter as soon as possible to prevent further damage if the previous owner has neglected it(oil change every 3000 miles)
Post by: Elite Pete on 28 May 2010, 18:49:40
Its a common one. I've just bought some 57mm alloy tubing and a 57mm silicone 90 deg hose to do away with the plastic turbo diesel bit
Post by: Welung666 on 28 May 2010, 18:53:50
Oooooo, where from?
Post by: Elite Pete on 28 May 2010, 22:34:01
Oooooo, where from?
Ebay, i'll sort some pics out ;)
Post by: markspark on 29 May 2010, 11:11:14
Well isn’t this weather blooming typical ive got up early to claen the engine so i can see what im doing and to work on it without getting total mucked up with oil and its persisting it down.
Maybe im better off waiting until Hoofing it has done his pump and got the pics that way i know what im looking at before i start
Post by: markspark on 29 May 2010, 11:14:37
Is it underneath where the pipe usally splits as ive had a quick look at mine and can’t see where its split
Post by: hoofing it on 29 May 2010, 12:49:34
well it's pishing it down here to so will see what the weathers like tomorrow.
you won't see the split until the turbo is preasurising the pipe when under load you might not see it with just reving the engine up. :y
Post by: hoofing it on 30 May 2010, 13:17:03
heres a couple of photos of what it looks like behind tne cover remember DON'T pull the wire any further than shown.
you can see the green O ring this is whats leaking on yours
(http://i978.photobucket.com/albums/ae262/broke-again/johns014-1.jpg)
this next photo shows hoe to get the bolts out you need to gently chap on a 6mm socket to get the security bolt out.
(http://i978.photobucket.com/albums/ae262/broke-again/johns015-1.jpg)
Post by: markspark on 30 May 2010, 17:24:50
thanks for them a big help now i know whats under there im thinking bead of silicon around allow to dry partly then bolt back up and see if that works
thanks
again
Mark
Post by: hoofing it on 30 May 2010, 19:04:18
thanks
again
Mark
DON'T use silicon mastic the diesel will eat through it use blue hylomar instant gasket :y
Post by: markspark on 30 May 2010, 20:00:37
thanks
again
Mark
i will get some tuesday and sort it out in the next week
thanks
Post by: markspark on 13 June 2010, 22:36:46
Did you complete this mod  :y
Post by: hoofing it on 14 June 2010, 11:10:45
I managed by pure chance to get one from a very nice chap at dealer. I was buying a maf and I mentioned about it and he said there was one on the shelf that has sat for over 2 years and for a £10 its mine.mine now :y
I priced doing it with hoses and was working out around £80.00 mark.The problem was finding one that can handle the preasure and not expand to much or burst.
Post by: Elite Pete on 14 June 2010, 14:00:54
Some pics here.
http://www.omegaowners.com/forum/YaBB.pl?num=1274886562
I'm just waiting for the fernox to do its trick in the rad then I will be fitting the new pipe so by tomorrow fingers crossed ;)
Post by: Elite Pete on 14 June 2010, 14:07:01
It cost me £26 for the alloy pipe and 90 deg silicone hose and its a proper turbo silicone hose and good for 15 bar ;)
Post by: hoofing it on 14 June 2010, 15:50:32
Some pics here.
great pics pete never had front off like that before :y
Post by: Elite Pete on 15 June 2010, 17:15:24
All the bits fitted
(http://i61.photobucket.com/albums/h64/pickledpepper/P150610_1635.jpg)
(http://i61.photobucket.com/albums/h64/pickledpepper/P150610_1635_01.jpg)
(http://i61.photobucket.com/albums/h64/pickledpepper/P150610_1635_02.jpg)
(http://i61.photobucket.com/albums/h64/pickledpepper/P150610_1645.jpg)
