Omega Help Area => Omega General Help => Topic started by: greebo on 16 June 2010, 21:13:31
can anyone help???? my alarm keeps going off for no rason. i've even gone as far as parking the beastly thing in my works workshop out of any wind to se iff it was that causing the problem. but after about 1/2 an hour the damb thing went off again. my neighbours ar kicking up a storm. 7 times last nite it kicked off!!!!! :'(
More than likely the batteries in your powersounder failing ... try a search on here for it :y
thanks. i did start a search, but got side tracked earlier. i'm thinking that it'll be going into the doc's. rather than heavy handed old me break something. thanks for the advice.
Hi,
Are you leaving a mobile phone inside the passenger compartment? as mine did that a couple of weeks ago and I found it was my daughters phone left in the centre console. Removed the phone and problem went away.
This is a regular question including from myself, as in my case not always the powersounder, check the bonnet switch this can get damaged easily.
To keep the neighbours happy, don't lock it with keys or fob, shut drivers door open rear, lean round and lock drivers door from inside, with keys in hand! shut the rear passenger door, car now locked no alarm set.
Even locking car via key sets the alarm :y
I had the bonnet switch problem, I just unplugged it and taped it up, been that way for the last 5yrs :) I think my problem was relating to having a black car as it only went off in the summer/on hot days, I can only imagine that the heat generated caused the bonnet or bracket to flex slightly. Nice easy test though.
