Omega Help Area => Omega General Help => Topic started by: viking6152 on 11 June 2010, 09:06:27
Title: 3.2 MV6 engine mods?
Post by: viking6152 on 11 June 2010, 09:06:27
Any advice on giving the engine a bit more? Is there a chip for a 3.2? :y
Title: Re: 3.2 MV6 engine mods?
Post by: Kevin Wood on 11 June 2010, 10:11:19
The chip is not replaceable on a 3.2. ECU is a sealed unit. It can be flashed so could possibly be remapped but I'm not sure who would do this or whether the gains would be worthwhile. On any natasp engine the gains are not going to be spectacular.
Post by: zirk on 11 June 2010, 12:22:53
The Remappers claim up to 20 Bhp, in practice between 5 to 10 more.
Post by: viking6152 on 11 June 2010, 16:48:04
Ah right, cheers guys. I have to admit though that i'm not mechanically minded when it comes to cars.If in doubt pay someone! I've been googling though and see that some :-/ :y owners have changed there air filters to K&N filters and fitted cat back exhausts even platinum spark plugs. Do these really do anything, does the car run smoother or run better mpg?
Post by: davethediver on 11 June 2010, 16:50:15
Don't bother with a K and N filter unless you want to change your MAF sensor sometime soon ;)
Post by: tigers_gonads on 11 June 2010, 16:56:13
get the dremel out for a bit of polishing and flowing but thats about it  :y
Post by: Mr Skrunts on 11 June 2010, 17:03:24
As mentioned, maybe a cat back system, but over and above that just keep the car well serviced.  Also try different brands of fuel rather than some of the supermarkets that just sell what they get at the best price.  Sounds daft but when I had my carlton I found my local garage's petrol (Cant remeber the brand though) seemed better for the carlton that the 2 other stations down the road.  Run your tank down to the red and they try each using say £20 at time in fuel, best tried over the same routes and speeds to compare say on the journey to work and back.  :y
Post by: tunnie on 11 June 2010, 17:11:31
a polished plenum will gain you more performance than fitting K&N, 3.2 is about as far as its going to go unless silly money is spent, so no cheap go faster mods  :(
Post by: viking6152 on 11 June 2010, 17:24:48
Cheers for the info. Is that a big job?
Post by: tunnie on 11 June 2010, 17:28:00
It would be easier and cheaper to drop a V8 in  ;)
Post by: viking6152 on 11 June 2010, 17:30:53
HA! Righto! Think i'll get some go faster stripes instead! :D
Post by: i260 on 14 June 2010, 21:44:46
Don't know where you are based but if you want to enquire further about a remap then contact John at DNA Tuning (http://www.dnatuning.com/index.php?option=com_content&task=view&id=149&Itemid=303). He is a really knowledgable guy and will tell you it as it is.
I had a V5 Golf done by him (used to get a forum discount then!) and the improvements were very noticable in pick-up and extra low-down urgnecy as well as better ability to rev out at the top end.
If I could justify the trip back to Stratford upon Avon and knew I was keeping my mig I would get my 2.6 mapped.
As with all remaps though you will need to run 97ron or 99ron to avoid pinking.
Post by: serek on 14 June 2010, 22:38:04
how much you want spend??
for about 2K£  you can fit kompressor kit with Eton M90 then you get about 280bhp :)
Post by: Rogusu on 16 June 2010, 09:37:56
For 2K£? Where can I get this? All I have found was around 10000 Euro somewhere in Germany (don´t remember the web page now).
Post by: feeutfo on 16 June 2010, 21:01:44
hmmm, so in the entire intake and exhaust system, top end, cams, compression ratio, squish band, all that stuff and whatever else is involved, there are no improvements to be made? no gains to be had? no emmissions issues or compromises to be got round?
Wow, thats got to be a first for production engine.
218 odd bhp from a 3.2 for example? not bad i guess, but surely there's more in there somewhere?
Post by: serek on 16 June 2010, 23:20:27
I dont say this is kit plug & play for 2£ but,
kompressor you can buy on US or germany ebay for 250-400£
ECU master- from 130£
kompressor mounting + wheels + belt -round 250£
intake manifold -200£
remap ECU-300£
and few other bits.
one of my mates will fit eaton M90 to his 2.5 so when I get more info will post here :y
Post by: Boracic on 16 June 2010, 23:29:41
How fast do you want it to be? lol, my 2.6 is fast enough, the 3.2 must be better
Post by: MikeDundee on 17 June 2010, 06:05:48
You only gain around 12/13 brake on a remap on 2.6 & 3.2 for around £295.00, website here: the S's that are blue have mobile remap services
http://www.mybluefin.co.uk/locate-dealer
Post by: Kevin Wood on 17 June 2010, 10:08:22
There's always more to come from an engine, it's just a matter of paying for it. ;)
There isn't a lot to be gained by chipping one (OP's question) IMHO and, given the cost involved on these ECUs I would doubt it's worthwhile.
Now, if you were to strip the engine and start again you could probably get quite a bit more power out of it by addressing the areas you mention and others but these days standard production engines don't generally have weaknesses that can be easily exploited for more power - naturally aspirated engines, at any rate.
Post by: karlc on 22 June 2010, 13:33:22
seem to remember someone in states having cadillac (us omega) that had a supercharger fitted and it was a car specific kit - try as i might i can't find it again on web! car was silver and was a v6 looked like a facelift elite it seemed straightforward with remap being flashed.
