Omega Help Area => Omega General Help => Topic started by: I_want_an_Omega on 26 June 2010, 19:01:36
Hi,
Can anyone advise where the engine number is located on a '98 V6 please.
Thanks
If I remember correctly it is on the passenger side of the engine above the oil filter housing. ;) ;) ;)
By the crank sensor & oill filter as Lizzie says http://images.omegaowners.com/images/guides/cranksensor_location/crank_sensor_engine_number_alt.JPG
Thanks peeps - nice & easy to get to then! >:(
Like most things on a V6 ;D ;D
Might not go as quick but you got to love the fourpots for ease of work under the bonnet ;) ;D
Most of the nonsensical things probably make perfect sense if the V6 is in a front wheel drive car. In particular the difficult to access oil filter, crank sensor, engine number and DIS would all be at the front of the engine bay.
its on the V5 Reg Doc
providing you know you have the original block in the car ::) ::)
