Omega Help Area => Omega General Help => Topic started by: weasel on 29 June 2010, 18:33:32
Title: 2 different drive shafts??
Post by: weasel on 29 June 2010, 18:33:32
Hi, i need a bit of advice on driveshafts, or outer cv joints to be precise, and i hope this makes sense....
I changed my diff a couple of months back, and the new diff had shafts already in it, so i intended on using these so i didnt have to pull the shafts out.
passengers side bolted onto hub fine, but the drivers side was completely differnet, the bolts were different spaces apart and it was a different shape.
So obviosly at some point the rear hub and drive shaft have been changed on my car, because the funny pattern on the end of outer CV joint wouldnt fit into hub, so i ended up using my original shaft.
Any one have any ideas as to what this rear hub and shaft may be off (2 litre possibly) because all other shafts/hubs ive come across 2.5 v6 auto and manual have been like the passengers side one?
Any help would be good
