Omega Help Area => Omega General Help => Topic started by: unlucky mark mv6 on 30 June 2010, 12:04:30
I know its been asked shit loads of times,but has anyone ever removed the leather covering on one of the front seats,as i need to try and repair the heater pad,and was it a barstool to do. :P
very hard apparently
Not sure if it's different for leather but this guide might give you an idea of whats involved. :y
http://www.omegaowners.com/forum/YaBB.pl?num=1192830810
OMG.............soooooo much of a pain. Easier to change a dispack with the scuttle left on................believe me.
.........and a bit like skinning the unfortunate German cow which donated it's epidermis in the first instance!! :(
i am interested in this too because my heated driver seat isn't working either :(
actually - removing the cover is quite easy, you have to take the seat out and dismember it, but other than that, it's all quite straightforward.
BUT (there had to be a but), the heating element is stiched into the leather and not able to be separated from it. So, if you're wanting to remove the leather / heater assembly to move to another seat or to change the foam or correct the seat base, then yes it's simple, but if you're going to attempt to fix the element, then I'm afraid it's not possible.
