Omega Help Area => Omega General Help => Topic started by: Omegafantasy on 01 July 2010, 00:16:06
Title: Still hesitating and gutless
Post by: Omegafantasy on 01 July 2010, 00:16:06
Hi all,
I got my new parts today (thanks AutoVaux for shipping to Norway!). Had some time at the workshop and replaced DIS-pack, plug leads and spark plugs. My old spark plugs still looked brand new, but I changed them anyway.
It got rid of my misfire - at last, but the poor miggy is still gutless like a 2-litre. With reference to my previous thread, http://www.omegaowners.com/forum/YaBB.pl?num=1274376988, I am pretty sure all vacuum hoses are connected as they should. At least the multiram works as it should. It struggles to reach about 4000 rpm and then "shoots off" (in comparison).
Does anyone have a clue about where to look next? It could be obvious, but I've become blind in the process..
Checklist (ruling out things):
- No fault codes (but the silly 136 remains when clipping. Zilch from "My Naff Code Reader").
- Fuel pressure up to standard
- HT-part is brand new
- Vacuum seems ok
- No obvious intake leaks
Title: Re: Still hesitating and gutless
Post by: zirk on 01 July 2010, 00:44:31
Not sure, are you sure all the vacuum pipes are all in the correct place?, any hissing noise on tickover?, compression test?, try spraying some carb cleaner over the vacuum pipes at high revs and listen for increased engine revs.
Chris.
Post by: same #same# on 01 July 2010, 00:50:39
Hi all,
- Vacuum seems ok
spark plugs gap wrong? or worn out.
Post by: Omegafantasy on 01 July 2010, 01:13:43
I have tried with carb cleaner to search for vacuum leaks, but nothing that I can find. The only hissing sound I can hear is what I consider normal from the intake. The pipes should be correctly hooked up, at least all components are functioning (both multiram flaps and FPR). All gaskets on the intake were changed when swapping engine (X25XE to Y26SE using X25XE electronics + plenum). EGR blocked off with dual gaskets and a 2mm sheet of steel at plenum side)
As for the spark plugs - they are brand new (as of today), genuine GM. DIS and plug leads original Bosch.
Compression test was done right before I got the engine - perfect condition. The old spark plugs I removed were all evenly worn (well, not worn at all).. Timing is also spot on.
I'm thinking about recording a video showing its performance in daily driving..
Someone suggested blocked cats, but I find that hard to believe as it's coming to life over 4000 rpm. A blocked cat would make it harder to rev it under load (experience from my Cavalier/Vectra that ate two cats in a year)..
Post by: same #same# on 01 July 2010, 01:19:18
i have herd that some omegas were restricted engine wise, has two driving speeds town drive and main road speed make it have no guts, should be able to see if its on with a tec2 on engine ecu, sounds like it maybe that.
Post by: Omegafantasy on 01 July 2010, 01:22:20
Hmm, I have never heard of such a thing, but it was ok with the previous engine in it (same ECU, loom etc.)
Post by: same #same# on 01 July 2010, 01:34:38
may of triped it when changing engine should see on a tec2 any way, when made they are on dif countrys change them to there spec. just put on tec 2 and check setttings, on mine i have it on when not going far( town driving), then have it turn'd off when going on a trip save a lot of fuel.
Post by: Omegafantasy on 01 July 2010, 01:38:04
As far as I know, Tech2 functionality is very limited on those ECU's (M2.8.1), but there's really no way of getting Tech2 plugged into my car here (hey, this is Norway  ::) ). I have "My Naff Code Reader" myself, but there's no such setting there..
Post by: same #same# on 01 July 2010, 01:41:50
it has it on "My Naff Code Reader", do engine read and its on the settings on that. move one of the boxes down and it on the list will say if its active or not.
Post by: Omegafantasy on 01 July 2010, 01:46:17
Hmm... Do you remember the parameter name?
Post by: same #same# on 01 July 2010, 01:49:08
off hand no says name in the box, if active it says active 0, then rev engine at point will change to in active, on mine its second page.
Post by: Omegafantasy on 01 July 2010, 01:56:10
That sounds like one of the solenoids for the multiram, but I will check it :)
Post by: same #same# on 01 July 2010, 01:58:42
hope it just that  good luck m8 :y
Post by: Omegafantasy on 01 July 2010, 01:59:32
Yeah, and thanks :D
Post by: Omegafantasy on 01 July 2010, 18:09:35
I'm just wondering; could the long Y26SE plenum be very different (performance-wise) than the X25XE plenum?
Maybe I should try to make use of the longer plenum.. Have to find a way to fit the IACV though.. The butterflies can be swapped.
Edit: Also, if anyone have the opportunity to check this on their X25XE/X30XE: Vacuum hose from the IACV to FPR - do you have any vacuum at all on idle? This thing rips me apart now  :-[
Post by: feeutfo on 03 July 2010, 10:23:22
Step at 4k is classic multi ram issue IMO.
Post by: Omegafantasy on 03 July 2010, 12:35:19
Aye, I know, but they're all working as they should when I watch them. Should really have a look at them under heavy load, but that might be tricky  :-?
Post by: feeutfo on 03 July 2010, 17:07:15
Certainly would  ;D
Maybe vac leak ? Not unusual for there to be enough vacuum to tickle the valve to see it move but not enough to keep it fully open. Its a bugger to diagnose. Rolling road?
Post by: Varche on 03 July 2010, 18:00:14
Could this be a problem with one of the vacuum tanks? The main one is low down on the left side of radiator looking back from the front of car. There is also another one on some cars under the scuttle next to the pollen filter.
Post by: Omegafantasy on 03 July 2010, 18:21:06
chrisgixer: I've been looking for vac leaks, but I can't hear or find any. Sprayed with carb cleaner in all the suspicious areas, but no detectable leaks. I might make a fixture to register the movement on the flaps. A microswitch glued onto something maybe? I'll see what I can do. No rolling road available :(
Varche: This one only got one vac tank under the scuttle and it keeps the vacuum for days (tried that, trust me) :)
I've made a little video showing some driving. Not that it's anything special, but maybe someone can compare to their miggy? This one will give you an impression of acceleration and sound in various gears. Right click and save as (78MB file). http://www.omcoslo.com/bil/omegadrive.wmv
Post by: Omegafantasy on 05 July 2010, 03:42:40
I'm about to go mad.. at least it feels like it.
Tried something new today: changed all the injectors and fuel rail to the ones from my 2.5 (in case of bad injectors) and it became a tad better, but nothing near what it should be like. Still hesitates really bad :(
I wish my Omega was like this again: http://www.youtube.com/watch?v=ml0mB8uiavA -- this one seems to be pulling forever :o
What should I try next? Throw away my cats? I hate being clueless.. This does my head in, lol..
