		Omega Help Area => Omega General Help => Topic started by: SJKOO01 on 04 July 2010, 14:36:38
				Not sure if anyone else has seen the information below, but Powerflex are producing currently producing the following:-
Front Anti Roall Bar to chassis bush (26mm)
And Front Wishbone Front bush
Click here to find out more
http://www.powerflex.co.uk/products/Omega+B+1994-2003-2658/1.html
Maybe of somehelp to you ?.
Admin, please move to the appropriate section if you feel this needs to be done ?.
OK, thats interesting for upgrades.
Maybe they will consider manufacturing the rear bushes too at some time.
Pontiac polyurethane bushes fit rear of Omega.
				Any particular pontiac? Bcause ive been looking into alternatives for sometime.
2003 - 2004 PONTIAC GTO PARTS:
NOTE - The following parts are for the 2003 - 2004 Pontiac GTO.
Front Struts will not fit but the Rear Shocks do, as will the Front & Rear springs.
The GTO is a version of the Holden Monaro. Its rear trailing (control) arm bushings will
fit the Catera/Omega.
Energy Suspension:
GTO Rear Control Arm Bushings: 33188R Control Arm Bushings (POLYURETHANE)
http://www.sfxperformance.com/parts/ENE33188R.htm
GTO Sport Ryder Springs (front & rear):
GTO SR Front Coil 0 Drop #2142
GTO SR Front Coil -20mm Drop #2151
GTO SR Front Coil -35mm Drop #2275
GTO SR Rear Coil -35mm Drop #2641
GTO SR Rear Coil -20mm Drop #2643
GTO SR Rear Coil 0 Drop #7643
Pedders GTO Sport Ryder Springs. All are 45% to 50% stiffer than stock.
http://www.peddersusa.com
GTO Rear Shocks:
GTO Touring CG Shock #8081 (street)
GTO GSR Rear Shock #9095 (street/track)
GTO GSR Big Bore Shock #9195 (track)
All Pedders shocks are firmer than stock to varying degrees.
				don't forget that if you change the rear semi-trailing arm bushes to something non-standard, then you'll have to run without the toe-correcting link fitted.
no sign of a front wishbone rear bush on the market yet.
Also try this firm as i know a few members have got them from here http://www.regal-shop.co.uk/
Kmac ones IIRC not listded as they come from OZ but ring them and see :y
