Omega Help Area => Omega General Help => Topic started by: I_want_an_Omega on 08 July 2010, 11:26:37
Can anyone advise what the process is for removing an auto gear lever once the centre console has been removed please.
I can see that there are 5 rivets to be removed, but cn I then do the rest from inside the car or do I have to get underneath.
It seems like there is a single coupling/joing which will go through the hole at the lower end - but I dont want to go about it in the wrong way and hope that I can do everything from inside the car.
TIA .......... Rob
you will have to drill the rivets out, then there is a single clip holding the lever to the selector shaft, so yes youll have to go underneath!, :y
