Omega Help Area => Omega General Help => Topic started by: Brick Tamland on 07 July 2010, 15:15:26
Title: 4 Pot leaking oil from sump sensor connector.
Post by: Brick Tamland on 07 July 2010, 15:15:26
just had a look under the car, oil is leaking from the sump sensor at the connection. The plastic connector feels loose in the sump.
Someone please tell me that the bottom half of the sump doesn't have to come off to tighten/seal it, because it looks that way as there are no bolts on the outside  :(
Title: Re: 4 Pot leaking oil from sump sensor connector.
Post by: Marks DTM Calib on 07 July 2010, 15:18:12
Ok, I wont tell you then.....(but it does)
Post by: Brick Tamland on 07 July 2010, 15:26:48
break >:(
Any idea how much the gasket costs. I doubt I could afford it ATM or to keep feeding it with oil :'(
Is there no way to seal it from the outside?  :-/
Post by: V6Astra F on 08 July 2010, 05:15:50
Hi
Sorry to say mate , but you cant do it without dropping the sump  :(. I have to do mine aswell in the near future on the V6.
Post by: same #same# on 08 July 2010, 06:27:27
is it split sump?? or singel,... 2.0L
Post by: tunnie on 08 July 2010, 09:02:35
Surely you should know, you have a 2.0  :-/
Back on track yup its sump off, not too bad a job really on 4 pots, just think of it as a very thorough oil change  :)
Post by: same #same# on 08 July 2010, 12:44:58
yeah but there is two types of sump split ones are easyer to get off then singal one.
