Chat Area => General Discussion Area => Topic started by: IrmscherKris on 06 January 2008, 17:09:17
Title: Nearly done the gearbox conversion!
Post by: IrmscherKris on 06 January 2008, 17:09:17
Lots of blood, sweat and tears... Now I'm tired so jumping in the bath for a soak :)
A quick question though. I only have to fit the clutch pipe, gear selector and prop. BUT lol.
The inhibitor switch is giving me a headache and thats why I'm leaving it till last. I know pin 28 is live when in P or N, so do I connect this up permanently OR connect it to a switch live wire?
Any ideas will be much appreciated.  :y
Title: Re: Nearly done the gearbox conversion!
Post by: Marks DTM Calib on 06 January 2008, 17:48:14
Are you refering to the solenoid on the ignition barrel that some have or the starter inhibitor?
Post by: IrmscherKris on 06 January 2008, 18:03:18
The starter inhibitor, to trick the ecu into thinking it's in P or N.
Post by: Marks DTM Calib on 06 January 2008, 18:17:30
Under the bonnet, just in front of the battery are 3 big round multiplugs.
Join the wires on pins 1 and 2 (both Black/Red) of connector X4 (the middle one of the three) together on the base part.
You also need to ground one of the pins on the MID to stop the autobox warning coming on (or re-programme with tech2).
Post by: Dave-C on 06 January 2008, 18:17:49
Surely just a link / bridge on the connector itself to loop the circuit, or, are you trying to do it at the ECU?  Did this on a Granny once!
DC
Post by: Marks DTM Calib on 06 January 2008, 18:20:33
Links are bad news as they have a habit of corroding the connector over time.
Pus there may be other pins on X4 that are still needed by the engine ECU so it has to be possible to re-fit the plug.
Post by: IrmscherKris on 06 January 2008, 18:21:30
Jeeze, talk about the definitive answer!
Thanks mate  :y
Post by: Dave-C on 06 January 2008, 18:23:49
Thanks mate  :y
Less concise than my reply! ;D ;D ;D
