Omega Help Area => Omega General Help => Topic started by: hoj on 21 July 2010, 23:33:01
Title: Water in pass footwell
Post by: hoj on 21 July 2010, 23:33:01
Think i seem to have seen several posts on this subject but cant find any in a search so i will ask again
Slight dripping has started in the passenger footwell seems to be right on the kick panel thingy on the very left side where it curves following the line of the door. (phew) I know we have had a lot of rain recently but it has only just started and has never been noticed beforehand.
Any ideas/common places  please as to where its coming in
Title: Re: Water in pass footwell
Post by: Gaffers on 21 July 2010, 23:35:28
Sounds like a blocked scuttle drain.
http://www.omegaowners.com/forum/YaBB.pl?num=1206287560  :y
Post by: CaptainZok on 21 July 2010, 23:38:35
Scuttle drain will be blocked.
Lift the pollen filter flap (nearside of scuttle).
Poke around in the murky water/silt/leaves in there looking for the drain grommet at the bottom.
Clear said grommet to allow water to drain out using stiff wire.
When it's empty clean out all the crud in there and ensure the drain is clear.
You'll doubtless need a new pollen filter make sure you get the grey active charcoal one for yours.
Post by: CaptainZok on 21 July 2010, 23:39:31
Oh and get it sorted sooner rather than later or it can bugger your fan speed controller.
Post by: hoj on 21 July 2010, 23:42:20
Cheers Gaffers &
Cheers Captain
Will come and see you soon regarding Cambelt
Post by: Entwood on 21 July 2010, 23:42:22
Once you've cleaned the scuttle drain start work on the carpets !!  The underlay/soundproofing beneath the carpet seems to be able to absorb an inordinate volume of water.... if you don't dry it out PROPERLY, within a few weeks it will start to stink......  horribly  :(
Post by: CaptainZok on 21 July 2010, 23:59:44
Cheers Gaffers &
Cheers Captain
No probs Roy, Sunday service only nowadays though.
He's at work the rest of the week. ;D
