Omega Help Area => Omega General Help => Topic started by: Sir Sideways on 31 July 2010, 11:05:52
Title: Facelift door mouldings removal?
Post by: Sir Sideways on 31 July 2010, 11:05:52
How do you remove facelift door mouldings? does the door card need to come off?
Thanks
Jim
Title: Re: Facelift door mouldings removal?
Post by: Elite Pete on 31 July 2010, 11:10:28
Hi Jim.
If your on about the plastic wood bits the door card has to come off, however, the plastic wood bits have what looks like a large plastic rivet which when removed would be difficult to re-attach.
Post by: nell77 on 01 August 2010, 13:08:27
or if you on about the ones on the door outer you will need a 10mm socket or spanner for the front indicator mouldings and a Torx for the door mouldings one at each end then slide the trim to get it off.
Post by: nell77 on 01 August 2010, 18:17:22
Think the torx is a T25
