Omega Help Area => Omega General Help => Topic started by: star_whites on 13 August 2010, 17:59:12
Title: Fuel Consumption
Post by: star_whites on 13 August 2010, 17:59:12
Not sure if I'm getting really bad consumption with my 3.0. I've noticed on tickover that it's doing 7 to gallon and driving around town it's averaging around 13 and that's with me driving like a learner, does this sound about right and if not what could be causing it  :-?
Title: Re: Fuel Consumption
Post by: PhilRich on 13 August 2010, 18:13:36
In need of a service?, dirty/missing air filter? blocked breathers? :-/
Post by: Lizzie_Zoom on 13 August 2010, 18:15:36
On tickover it should hover between 0.3 and 0.4 mpg, and even down to 0.2 without the a/c on.  That is what mine does anyway ;) ;)
Around town mine returns about 18 / 19 mpg ;) ;)
A good service, including all filters and plugs changed, with the breathers cleaned out should make a big difference :y :y
Post by: star_whites on 13 August 2010, 18:29:32
Breathers and plugs were recently done when I did cam cover gaskets so it surely can't be them.
Post by: Lizzie_Zoom on 13 August 2010, 18:35:14
Well something is 'holding' your car back :P :P
Are the brakes ok, and not binding?  Is your exhaust all clear without obstructions that are building up back pressure?  When was your cambelt last changed and by whom?  :-/ :-/ :-/ :-/
What revs does your car idle at?
Post by: star_whites on 13 August 2010, 18:47:41
Cam belt was done by me last year when I rebuilt the engine and was set up with the cam tools. Brakes are in need of changing but not binding as far as I'm aware. Exhaust is blowing at manifold but other then that I think it's ok
Post by: Andy H on 13 August 2010, 18:54:16
That would do it.  :y
A leaking exhaust manifold can let air in as well as exhaust out. The extra oxygen convinces the ECU that the engine is running lean so it chucks more fuel in and crucifies your fuel consumption and emissions.
Fix the manifold gasket and that should fix it :y
Post by: Lizzie_Zoom on 13 August 2010, 18:56:33
Yep Andy, that certainly would lower mpg! :y :y :y
Post by: star_whites on 13 August 2010, 19:04:34
It's actually a cracked manifold but haven't managed to get hold of a replacement yet
Post by: PxMetro on 15 August 2010, 10:31:19
For interest, I took my 3.2 MV6 Auto down to Devon last week using A/B roads and Motorways, and it returned about 31MPG. Local driving normally returns about 25MPG. Tickover in "Drive" on the Instant readout shows 0.4 and Tickover in "Neutral" shows 0.3. Interestingly with the air conditioning turned on adds 0.1 to each of these respectfully.
Post by: Iain on 15 August 2010, 10:40:28
Erm the instant consumption changes from miles per gallon when running to gallons per hour at idle,so it would have been 0.7 gallon per hour,meaning it will sit ticking over all day and use 0.7 gallons every hour :y
That not right?
Post by: PhilRich on 15 August 2010, 12:12:15
That not right?
Yes, absolutely spot on Iain :y
