		Omega Help Area => Omega General Help => Topic started by: zirk on 16 August 2010, 16:17:16
				OK, quickie, Im about to swap Steering Wheels, doe it it matter if the Airbag is also swapped or is it best to use the original from the car?.
 Battery off, wait 30 mins, pop the cover and remove, anything else I need to know?
 Cheers Chris     :y
				that about covers it
				Thanks TB  :y
				I suppose the original one would be less likely to be defective. (i.e. throwing up fault codes & putting on warning light)  Easy job. :y
