Omega Help Area => Omega General Help => Topic started by: Neil_MV6 on 15 September 2010, 19:59:24
Title: HELP - Fuel filler cover won't unlock!!!
Post by: Neil_MV6 on 15 September 2010, 19:59:24
Stopped for fuel in Nottingham today before my drive home to Sutton Coldfield and couldn't open the fuel filler cover...it hasn't unlocked with the central locking.  >:(
Luckily I had just enough fuel to get home.
Is there a way to manually unlock it? Is there a specific fuse that could have blown or is it likely to be something to do with the lock itself?
Title: Re: HELP - Fuel filler cover won't unlock!!!
Post by: charlie on 15 September 2010, 20:03:11
THe answers in the manual :y :y :y http://images.omegaowners.com/documents/UserGuides/OmegaOct2002.pdf page56
Post by: The Red Baron on 15 September 2010, 20:04:18
probably the locking motor in the boot up inside above the inner arch.
Post by: davethediver on 15 September 2010, 20:07:41
OPen the little first aid compartment you will see the locking motor disconnect it you can try and fix it with some lube.
I threw mine in the bin and bought a known good one for a fiver fit that job done :y
Post by: Neil_MV6 on 15 September 2010, 20:47:43
Cheers guys, just found my manual and spotted it too.
Thanks for the replies!  :y
Post by: Marks DTM Calib on 15 September 2010, 20:55:55
Wiggle the leads to the connector and work it a few times.
The wiring can get knocked when things get chucked in the cubby holes
Post by: Neil_MV6 on 17 September 2010, 09:25:22
I did a wiggle of the wires and it worked but only intermittently.
Will get it out tomorrow and give it an 'overhaul'.  :y
Post by: RobG on 17 September 2010, 10:04:45
Got a spare here if needed :y
