Chat Area => General Discussion Area => Topic started by: Andy B on 11 January 2008, 12:01:38
Title: fuel consumption
Post by: Andy B on 11 January 2008, 12:01:38
I know it's a well hammered topic ......
As mentioned in another topic I went to Edinburgh, and , as you do I reset the fuel trip.
The last time I went anywhere (without a caravan ;)) the best consumption I've ever seen on my 99 3.0 Elite has been about 27mpg driving at a steady 75 mmph using cruise. Wed afternoon with 4 adults in the car I saw an incredible 32.4mpg at a steady 80mph (once I'd got pased the M55  ;)) Even after driving around Edinburgh's traffic free city centre  ;D for a day, the return to home - without resetting the trip - I've still got nearly 29 mpg!
I haven't done anything in particular that I think has contributed to an increase in mpg. Perhaps I should apply to the Pope for miracle status! :y
Title: Re: fuel consumption
Post by: IrmscherKris on 11 January 2008, 12:04:24
Andy, thats really good mate. More than I got in the TD (26) I have put a stick shift in there now though so it's bound to improve...
Post by: Paulus on 11 January 2008, 12:27:37
Well I hope you're sitting down...
I tend to do most of my travelling on the motorway...usually at 60mph to avoid the idiot white van and BMW drivers.
I frequently get 39-40mpg at that speed...from my '98 3.0...However, as soon as I even look at the pedals, that plummets.
Post by: stuart30 on 11 January 2008, 12:37:23
Well after complaining about the mpg i get out of the Elite (mostly town driving) i was shocked just how great it is on a run....cant remember exactly now (think i posted them before) believe they were around 30 + mpg.
Just simply turning the ECO on has made a major difference....5/7 mpg extra by having it on,mind you i do drive like a grandad which kinda begs the question why did i buy a 3.0 ltr. ;D
Post by: Andy B on 11 January 2008, 12:42:55
...... on the motorway...usually at 60mph.........
Is that legal?  ;D  ;D  ;D :y
Post by: Jay w on 11 January 2008, 12:46:58
anything abover 30mpg is good with an Omega.
On a run i currently get 20mpg with my 2.5V6, however i am running LPG and that is half the price of petrol  :y
Post by: Andy B on 11 January 2008, 12:48:23
Just simply turning the ECO on has made a major difference.........
... that's something else though I need to get to the bottom of. The car mists up all the time when it's raining unless I have the CC set at just the screen - fan knocked down to 4/5 though. WhenI got back last night i noticed that the REAR screen was still misted up between the high/eye level brake light & the glass. :-? That was after 4 hours on the motorway.
Post by: Andy B on 11 January 2008, 12:50:23
..... however i am running LPG and that is half the price of petrol  :y
Going off the trip I used 16.1 gallons of petrol.  :(
Post by: Jay w on 11 January 2008, 12:50:51
there are two vents in the rear quarter that should allow the freeflow of air.
if you have too much in the right hand storage 'cubby hole' it will stop the vents froom working and causes misting
Post by: Andy B on 11 January 2008, 12:53:19
They're both clear. I did have a bottle of screen wash that'd fallen in front of them, it was full of condensation when removed  ::) but there's nothing there now. Earlier last year I found the front passenger side footwell FULL of water - scuttle drains already clear - but I couldn't find an obvious point of entry, and it seemed to stay dry after I'd dried it out. I think the 2 are connected.
Post by: Darth Loo-knee on 11 January 2008, 13:25:18
I think it sounds silly but I find that my car does better on MPG when sitting at 80-85 mph, I drop to 70 mph and you see the computer consumption drop too.
I was told years ago that 3000 rpm was a cars engine cruising speed....
Post by: Andy B on 11 January 2008, 14:45:15
Just been having a play with the air con/CC. Just had it on 'LO' for the last few minutes home and the dryer? (ally wotsit in the rubber refrigerant line) isn't at all cold. :( Something else to spend some money hard earned on if I want it to work as intended.
Post by: SP_3.2 on 11 January 2008, 16:07:32
Just thinking that the system may just need a regas. do you get a jump in the rpm with the c/c is swiched on?.
Post by: Martin_1962 on 11 January 2008, 16:09:07
My best is 27 on a run - on LPG ;D
Post by: Paulus on 11 January 2008, 16:09:51
When I was working away from home, I had a 200 mile drive to kill, so I spent many hours playing to see what works and what doesn't.
Switching the air-con off (ECO button) only gave about 2mpg.
60mph gave 40mpg.
70mph gave 30-35mpg (depending on hills 'n' stuff).
80mph gave 25mpg.
I was bored...very bored...very bored indeed. Burgess Hill is a long way from Stafford.
Post by: Andy B on 11 January 2008, 16:34:23
Mmm! I think you're correct. The revs do rise & fall as expected but ...
a rise in revs isn't a difinative answer to whether the A/C compressor is clutching in. At some time in the past, before I got the car, the electrics to the A/C have been played with. There's an earth/ground/0 volts/whatever you want to call it  ;) under the battery that had been fiddled with. So, as you do I put it back to how it Vx had originally intended - the A/C packed ie the compressor didn't clutch in although there was a rise & fall in the revs when you put the A/C on or off. When I put the wiring back as was the A/C worked. The revs are obvioulsy not requested by a pressure rise or fall in the refrigerant lines.
Post by: Kevin Wood on 11 January 2008, 16:40:30
The signal to the air con compressor clutch passes through the engine ECU, IIRC, so the engine ECU can veto the use of air conditioning (if coolant temp is too high, for example). If there is a break in the circuit further on in the system, ECU will see that air con is on, thus raising idle speed, but clutch won't engage.
There are manual pressure and temperature sensors which can disable air con compressor. Definitive way to tell if it's running is to watch the compressor pulley. If the front of the pulley with the 3 round weights on is spinning, it's running.
Post by: Andy B on 11 January 2008, 17:05:40
...... There are manual pressure and temperature sensors which can disable air con compressor. Definitive way to tell if it's running is to watch the compressor pulley. If the front of the pulley with the 3 round weights on is spinning, it's running.
That's how I realised the A/C had stopped working after I'd 'corrected' the wiring. It's to dark outside now, I'll look tomorrow. there's a good A/C specialist just up the road. I'll take it too him as the system hasn't had anything done to it while I've had the car [size=8](apart from a can of R134a last summer :-/)[/size]
