		Omega Help Area => Omega General Help => Topic started by: Kneepad on 16 September 2010, 21:56:56
 I knocked off the head of the securing bolt with a chisel.
 Couldn't undo the threaded part from the wheel.
 Tried to drill into it to use a screw extractor and broke the drill bit.
 Can't grip with pliers or molegrips.
 Any suggestions
				I've no idea what you have in front of you but a hammer and centre-punch can often walk a headless screw out if you hit as near to perimeter as you dare and at an angle to drive anti-clockwise.
				Thanks Chris, but I did have a go at that it just
 chewed it up more. If it had been a larger diameter
 I may well have had more success with that method.   :y
 I'm now contemplating drilling into it through the
 back of the with wheel, first with a drill larger than the
 diameter of the hole and then with a smaller one.
 Hoping that the broken drill is not all the way through
 the bolt.
				Use a cobalt drill bit
 Ok, Thanks, I'll give that a try, before any more butchery.
 Just ordered a couple of bits from Toolstation.   :y
