Omega Help Area => Omega General Help => Topic started by: Tezzyd on 30 August 2010, 17:54:42
Title: Unusual beeps
Post by: Tezzyd on 30 August 2010, 17:54:42
I have a petrol 2.2 Omega cdx 2001 and just recently i have been getting 4 bleeps from under the bonnet when i switch the engine off. I thought it could be the alarm but i hadn't even left the car. It has only happened a couple of times within the last week but not every time.
Can anyone shed some light on what could be causing this please
Title: Re: Unusual beeps
Post by: PhilRich on 30 August 2010, 17:58:46
Don't quote me on this as not 100% sure, but I think the Powersounder on the Alarm gives warning beeps when the batteries are getting to the end of their life? I understand they can leak & have caused vehicle fires in the past. I'm sure someone will be along shortly with a definitive answer though  :y
Post by: Broomies Mate on 30 August 2010, 18:07:24
^^ Exactly this.
Check this thread   http://www.omegaowners.com/forum/YaBB.pl?num=1220198611 for a howto disconnect it before your car gets rather toasty.  :y
Post by: Tezzyd on 30 August 2010, 22:38:50
It's definately not the battery as i have 4 for the sound system and floats on 12.6v which has been in there quite a while. I think it is the sounder but i thought the 4 beeps might mean something like a pc when it has problems booting up as in an error code but i can't find anything in the hand book.
I play a lot of bass i may have shook something loose.
Post by: Andy B on 30 August 2010, 22:41:56
It's definately not the battery as i have 4 for the sound system and floats on 12.6v  .....
Phil means the power sounder's batteries, not the car battery  :y
Post by: Tezzyd on 30 August 2010, 23:05:26
Yes!! that make sense, It helps if i read the replies right, thanks for that.
Next question is, what sort of batteries does it take.
Post by: Andy B on 30 August 2010, 23:09:04
here you go!  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1240077701
Post by: Tezzyd on 31 August 2010, 21:16:41
Excellent :y  Thanks a lot for all your replies I will give this ago :)
Post by: Tezzyd on 20 September 2010, 18:42:55
Just an update. I got the batteries from here:
 http://www.budgetbatteries.co.uk/20940/3-v150h-size-mempac-nimh-3-6v-150mah-varta-rechargeable-memory-protection-battery-pcb-mount/
£9.99 for the pair delivered and all is sorted. Cheers  :y
Post by: smithpa7 on 20 September 2010, 18:56:58
Good news, Tezzyd :y :y
Post by: PhilRich on 20 September 2010, 19:10:44
Well done :y And thanks for the link for replacement batteries, very useful :y :y
