Omega Help Area => Omega General Help => Topic started by: graham-mv6 on 27 September 2010, 09:12:55
Title: Help needed 2.6 v6 stalling and hesitation
Post by: graham-mv6 on 27 September 2010, 09:12:55
Hi everyone have problem hope someone can shed some light on situation when car is started the revs climb to 700rpm then drop to 0 cause it to stall unless i hit throttle, in which case its fine.  There also slight hesitation this doesnt happen to often.  I have been informwed coil packs have been changed so is it crank sensor? airflow meter? the engine management light has not come on at any point.
Thanks
Graham
Title: Re: Help needed 2.6 v6 stalling and hesitation
Post by: Welung666 on 27 September 2010, 14:16:09
Try doing the pedal test (see link at the bottom of my post) to see if any codes are stored :y
