		Omega Help Area => Omega General Help => Topic started by: mc1 on 25 September 2010, 17:40:07
				hello all
 i have the tc & abs warning lights on and the speedo stops working any ideas? :-/
				Hi
 Classic symptoms of a failed ABS ECU.  Repairs to your item are available for about £100 from BBA Reman.
 Alan
 hello all
				You don't say where you are, but there is also another company in Nottingham.
 Both repair for a minimum of £100 or more. Do a web search.
 There is a how to in the maintenance guide on the forum. Quite a fiddly job but doable. Just takes patience.
				Mine cost £128 inc vat and postage from BBA-Reman. Quick turnaround. I hear ECUtesting.com offer a good service aswell.
 Personally I think repair is better than 2nd hand as the same could happen, and it might be difficult to source the part.
 You will need the combination of angled screw driver and extension bars as stated/pictured in the guide, I found it easier to use one of the flexible screwdriver extensions (picture a spine in your head). That way you can bend it to the exact size/shape/angle that suits you.
 It took me 5-6 hours to get it off and the same to put back on near enough. Would be quicker now though. It's got to be better than the reported £800-£900 Vx charge!
 HTH
				thanks guys for your info.i dont think i have the patience to do it myself so i will have to search www and pay the £100+. thanks again much appreciated. :y
				also a sympom of either ABS relay or wheel speed sensor failure
 The £100+ is to get it fixed, it still has to be removed which is where the cost escalates if paying someone else to do it
