Chat Area => General Discussion Area => Topic started by: Ken T on 12 January 2008, 18:25:39
Just saw this on Ebay, very cheap so far. http://cgi.ebay.co.uk/2003-Vauxhall-Opel-Omega-2-6-v6-manual-spares-or-repair_W0QQitemZ320204431110QQihZ011QQcategoryZ9858QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Ken
Even cheaper http://cgi.ebay.co.uk/2001-Vauxhall-Opel-Omega-Elite_W0QQitemZ200191492528QQihZ010QQcategoryZ9858QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hmm.. by the time the first one has had a new engine, rear bumper, bonnet... :-/
And before bidding the second one, I'd want to see better pics of the "few knocks" ;D
i saw that too, but the you would need a drive-by-wire engine to replace it, which are harder/more expensive to get hold of.
Do you do everything by the book? ;)
;D
IIRC, the 1998 on engines have the fixings on the heads for the coil packs, etc...
I just wonder if you could somehow put a 2.5/3.0 in there, given they are mechanically almost the same beast...
EGR? throttle control? Cruise?
Use all the electrics off the old engine - literally just transplant block and heads? (And change the OS manifold?)
I am just wondering about the throttle and tc and stuff, since the 2.6 has electronic thottle control... guessing its a tech2 adjust for the ecu... and push the cable though the bulk head! ;D
IT JUST AINT WORTH IT! ;)
I'd suggest journal grinding and bearings
Or use a 3.0 block, crank ect
Or just pull the dent out of this.....
http://cgi.ebay.co.uk/2001-VAUXHALL-OMEGA-ELITE-V6-BLACK_W0QQitemZ260201571830QQihZ016QQcategoryZ9858QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Already had the VIC check
