Omega Help Area => Omega General Help => Topic started by: doug4293 on 30 September 2010, 00:53:41
needing new rear shock absorbers for my 3.0 elite (1996) it doesnt have xeon lighting and i dont think it has rear self leveling suspension, on my last visit to maccess they showed me a rear shock absorber but it didnt have any where for the tubes i have on mine to be fitted, on each of the rear shock absorbers there is a small tube which goes to each rear shock. its is about half the thickness of windscreen washer tube, anyone have any idea what its for ?
Those are self leveling shocks you describe
The tubeing is to supply compressed air to the shocks
As said, those are the air pipes to the shock body, you do have self levelling suspension. Have you heard the pump running in the drivers wing on start up?
yes i had a listen for it today and it runs for about a min once car started, now i have read on here that i can replace with standard shocks, and take the fuse out for the pump, from what i seen in the hayns manual the same fuse runs other things like glove box light, reverse lights ect, so how can i stop the pump running if i put standard shocks on (assuming the self level ones are too dear)
Disconnect the pump. :y
Or pull fuse #27
Turn the page ;) you just need to pull need Fuse 27 - automatic level controls system :y :y :y
okay thank for the help, will pull fuse tomorrow, and go for the standard £28 a side shock absorbers me thinks,
TBH I teed to pull the relay, small one top right of the cabin fuse/relay box.
Nah, its a convenient "in car" spare for when the main deam relay dies ;D ;D
Joking aside, pulling the fuse or the relay do have same effect...
