Omega Help Area => Omega General Help => Topic started by: mrjimbo on 10 October 2010, 21:03:42
The air con pump has decided it doesn't want to kick-in, not sure if it's the clutch or an electrical problem.
How do you check the clutch ? i know you have to connect 12v to one of the terminals on the pump but not sure which one.
I've seen several post on here about it but i can't find them, can anyone help ?
TIA
Taken from another post, this is the a/c clutch connector on a 2.5V6, should look similar on yours I believe:
http://picasaweb.google.co.uk/107486209918697739232/20100926#5521340545994158450
The air con pump has decided it doesn't want to kick-in, ....
it won't kick in if there's no gas in the system :-/
Ah so thats where the plug lives :y
Just need to find which terminal to put the 12v to.
Cheers aaronjb
