Omega Help Area => Omega General Help => Topic started by: pjd7325 on 21 October 2010, 16:11:16
Title: Servicing
Post by: pjd7325 on 21 October 2010, 16:11:16
I am going to attempt to do a mini service on the omega tomorrow. All though it was done at 65K (now got 68k) it was back in 2009 so needs to be done really. Apart from the oil/filter change, airfilter and pollen filter is there anything else I should do while I am at it? Fuel filter has been done.
Title: Re: Servicing
Post by: david036 on 21 October 2010, 16:28:39
Always worth giving the brakes a clean and a check...
Post by: Lizzie_Zoom on 21 October 2010, 17:13:50
Yep, make a point of cleaning the breather system! ;) ;)
Post by: Auto Addict on 21 October 2010, 17:42:09
Plugs?
Post by: TheBoy on 21 October 2010, 17:57:26
brake fluid change. coolant change.
Post by: Auto Addict on 21 October 2010, 18:05:07
Where does it end.... ::)
Post by: aaronjb on 21 October 2010, 19:30:54
It's like painting the Forth Bridge.. it never does! ;)
Post by: Andy B on 21 October 2010, 19:57:36
actually   ;) ............  http://thescotsman.scotsman.com/scotland/Theyve-got-it-licked-.5058126.jp  :y
Post by: aaronjb on 21 October 2010, 20:00:01
*mutters*
I'll get me coat..  :P
Post by: Kneepad on 21 October 2010, 20:26:59
I wonder if you can buy it in litre tins.   :D ;D
Post by: pjd7325 on 21 October 2010, 20:53:45
Cheers for the replies. The brake fluid, coolant and plugs were done at the 65K service so I wouldn't of thought they would need doing yet? Good point about the brakes I'll give them a clean and check the pads and check suspension etc. Hope nothing goes worng like it normally does when I attempt things like this!
Quite agree with the forth bridge theory!!
Post by: V6 CDX-er on 21 October 2010, 21:16:22
Whilst on the subject of servicing, I haven't seen any mention of lubricating the propshaft on these Omegas.
I've yet to have a good look under mine, but I assume that there are grease nipples? Having had a propshaft UJ fail on my Land Rover at around 20mph, I dread to think the mess such a failure would cause at 70mph+?
So maybe add greasing the prop to your list?
Post by: robson on 22 October 2010, 10:26:16
Grease nipples are there such a thing on cars these days?
Post by: Osprey on 22 October 2010, 12:03:52
From recent, bitter experience, I second Lizzie's point.  The breathers will get blocked - they all do - and that will blow your cam cover gaskets and eventually your HT system.   >:(
Unblocking the breathers (guide in the maintenance section) involves squirting carb cleaner and shi foreign matter into the oil, so do the oil change afterwards.
As for the rest, this is what I am working to, gleaned from OOF, Vx service book and Arthur's manual (V6 petrol - others probably different):
5000 / 6m
Engine oil and filter
10000 / 1y
Check lights, brakes, aux belt, hoses, exhaust, suspension and steering (including tyre wear, esp inside edge )
General poke around for leaks, worn or broken stuff, or anything suspect
Steering & suspension geometry check
20000 / 2y
Clean out crankcase breathers
New air and pollen filters
Check ATF level, handbrake shoes, driveshaft gaiter
40000 / 4y
New timing belt & tensionner kit, aux belt and water pump
New plugs, fuel filter, brake fluid and coolant
70000
New ATF and filter
Empty ash trays
Post by: V6 CDX-er on 22 October 2010, 12:11:34
Dunno.
Just waiting for my Trade Card to turn up from autobahnstormers, then I'll get it over the pit and have a good look.
TBH I'd be suprised if there wasn't some way of lubricating the U/J's?
Post by: Andy B on 22 October 2010, 12:15:08
Grease nipples on a modern U/J?  They'd gone at least as far back as my 1973 Cortina. Industry still has them, but long gone on cars, all sealed for life.  :y  :y  :y
Post by: bigdods on 22 October 2010, 13:04:54
my '97 TVR has grease nipples on the propshaft UJ and if you dont grease it every 6k miles it can get very rough.
Post by: Andy B on 22 October 2010, 13:08:53
I stand very much corrected. But you wouldn't call a TVR a 'normal' car though.  :y :y :y
When I get a Chimaera or Griffith I'll remember that!!  ;D ;D
Post by: V6 CDX-er on 22 October 2010, 13:11:23
Ah, a fellow Chim owner!    8-)
(http://i302.photobucket.com/albums/nn85/TVRMoneypit/TVR%20rebuild/tvr-rebuild038.jpg)
(http://i302.photobucket.com/albums/nn85/TVRMoneypit/TVR%20rebuild/tvr-rebuild017am.jpg)
(http://i302.photobucket.com/albums/nn85/TVRMoneypit/TVR%20rebuild/Chatsworth_park_2007_011.jpg)
Mine ^^^^^^^   :D
Post by: aaronjb on 22 October 2010, 13:40:28
Ooh, totally off topic but.. I have never seen pictures of a Trevor without it's clothes on.. Do you have any more? :)
Post by: Kevin Wood on 22 October 2010, 13:44:36
Doesn't look very different to a Westfield without its' clothes on. ;D
Post by: Andy B on 22 October 2010, 13:49:11
 ;D  ;D  ;D  ;D  ;D
Post by: V6 CDX-er on 22 October 2010, 13:49:35
(http://i302.photobucket.com/albums/nn85/TVRMoneypit/TVR%20rebuild/tvr-rebuild006.jpg)
This was before the chassis refurb, just after the shell had come off. Once all striped down it was sent off to shotblasting, then onto the jig to have new sections welded in, (thicker outriggers, and some of the tubular sections around the rear), along with better and fuller welds in the areas that needed it. Then shotblasting again, powdercoating, a couple of coats of Hammorite, then re-assembly.
And below if another one of afterwards.
(http://i302.photobucket.com/albums/nn85/TVRMoneypit/TVR%20rebuild/tvr-rebuild041.jpg)
Post by: Radar on 22 October 2010, 13:55:48
5000 / 6m
10000 / 1y
20000 / 2y
40000 / 4y
70000
New ATF and filter
Empty ash trays
You obviuosly are not smoking enough!
Post by: aaronjb on 22 October 2010, 14:01:48
For some reason, I was quite surprised about that.. no idea quite what I was expecting to see, though ;) Although I think the Tamora is a monocoque?
Nice - sounds like a lot of work, but worth it to keep something like that on the road, I'm sure :)
Post by: Welung666 on 22 October 2010, 21:22:59
Paul, give me a call in the morning and I'll show you how to do the breathers. That way you can do them yourself next time ;D :y
Post by: V6 CDX-er on 23 October 2010, 01:40:28
Sorry. One more for you. Just after it came back from powdercoating;
(http://i302.photobucket.com/albums/nn85/TVRMoneypit/ub3005.jpg)
Post by: Andy B on 23 October 2010, 09:00:13
Sorry. One more for you. Just after it came back from powdercoating; .....
It looks too nice to hide under a car and get dirty  ;D
