Omega Help Area => Omega General Help => Topic started by: feeutfo on 24 October 2010, 10:34:07
Title: 3.0 Ar35 into a 3.2
Post by: feeutfo on 24 October 2010, 10:34:07
Any problems to expect from a 3.0 ar35 box replacing a 3.2 ar35 box ? Are they the same? There is a suggestion that there are some differences in the thread below....
 http://www.omegaowners.com/forum/YaBB.pl?num=1287779173
Title: Re: 3.0 Ar35 into a 3.2
Post by: Elite Pete on 24 October 2010, 10:39:34
Straight forward swap Chris, like for like ;)
I'll just add, I used the mini facelift torque convertor ;)
Post by: Elite Pete on 24 October 2010, 10:52:42
This Omega was one I did many years ago. It had a faulty box and the new box came from a mini facelift  ;)
 (http://i61.photobucket.com/albums/h64/pickledpepper/DSCF0003-3.jpg)
Post by: serek on 24 October 2010, 15:08:53
yes they will work but ,  box from 3.2 got different flexplate like Entwood say,
 and gearbox from 3.0 dont change gear so smooth
like one from 3.2
need ask Sassanach hi will put some light on this.
Post by: feeutfo on 24 October 2010, 19:16:12
like one from 3.2
Not sure where the flex resides in the box, guessing bell housing? In which case I presume 3.2 item will fit on the 3.0 box? The 3.0 box has no bell housing or associated assembly, so we will need that part from 3.2 anyway?.... :-/
Post by: aaronjb on 24 October 2010, 19:20:56
Flex plate takes the place of the flywheel in a manual car - so it goes crank->flex plate->torque convertor->input shaft (and yeah, all in the bell housing)
If the 3.0 box has no torque convertor, was it definitely removed properly? (i.e. box & tc off engine, tc off box in that order)
Post by: 2woody on 24 October 2010, 19:29:18
3.0 has tc with it - I just wanted to keep the bellhousing
Post by: aaronjb on 24 October 2010, 19:31:29
Ahh :) I see (said the blind man)
Post by: feeutfo on 24 October 2010, 20:06:26
Bah, should be able to make a good one out of the two....surely?
Post by: Marks DTM Calib on 24 October 2010, 20:23:47
Yes, reuse your bell housing, flex plate and torqe convertor and fit the 3.0 box.
I should add, I would fit the modified thrust washer first (Sonax item)
Post by: feeutfo on 24 October 2010, 20:37:58
Good point re washer, car is 03 3.2, did all cars have the same problem with the washer? Presume yes or you would have said....
....and the fault is box lost all forward drive after a stretch in limp mode, and has an atfl leak, level re filled and still no drive....history, rear crank seal replaced about 9months ago and box itself was overhauled by a private firm a couple of years before that for a hefty sum.
Just thought we should be belt and braces in case any other thoughts come up with anyone. Selector lights all work correctly...
