Omega Help Area => Omega General Help => Topic started by: babes99 on 24 October 2010, 17:10:53
Title: alarm
Post by: babes99 on 24 October 2010, 17:10:53
I have a 2000 v reg omega 2.o litre cdx. I want to reset the managment unit but everytime i disconnect the battary the alarm keeps sounding help how do i stop the alarm
Title: Re: alarm
Post by: dbug on 24 October 2010, 17:13:35
Disconnect battery within 15 seconds of turning ignition off  ;)
Title: Re: alarm
Post by: babes99 on 24 October 2010, 17:30:30
Thanks just read that in the drivers manual  :D
Next question and this one is a bit harder.  :'(
Stopped the car and put the gearshift in park then all the dash lights failed. All of them. then on the right hand side of the dash there was smoke and a burning smell of rubber or plastic. when i went to start the engine again it came up with a automatic transmission fault and went into limp home mode. Any ideas as to what could have been burning?
Title: Re: alarm
Post by: Andy B on 24 October 2010, 17:49:44
.... then on the right hand side of the dash there was smoke and a burning smell of rubber or plastic.  ......
The 'power sounder' ie the battery back up alarm siren, lives under the plastic scuttle on the driver's side of the car. It's not unheard of for them to set on fire. It does sound like yours has burnt out, perhaps taking something else out with it.
Title: Re: alarm
Post by: babes99 on 24 October 2010, 18:48:13
This being the case wouldn't the alarm be silent when disconnected from the battary? Because it isn't it still sounds when we disconnect the battary  :-/
Any other ideas what it could be? I will rip the dash out if i have to be i would rather not :(
Title: Re: alarm
Post by: Kneepad on 24 October 2010, 19:55:31
No, it has it's own internal batteries.
Title: Re: alarm
Post by: Andy B on 24 October 2010, 19:59:13
The clue was in the description ....... battery & back up  ;) ;) ;) :y :y
Title: Re: alarm
Post by: babes99 on 25 October 2010, 04:46:36
ok do i have to take the dash apart to get to the 'power sounder' or can i just remove the instrument panel?
Sorry for asking so many questions but i have only had this car three weeks.  :(
Title: Re: alarm
Post by: albitz on 25 October 2010, 06:21:19
No need to disturb anything inside the car. It lives under the o/s off the scuttle panel. Under the wipers. I think there may be a guide somewhere.
Title: Re: alarm
Post by: Andy B on 25 October 2010, 09:16:26
The power sounder lives here..... http://www.omegaowners.com/forum/YaBB.pl?num=1220198611 and if you feel you want to have a go at replacing the internal batteries then that guide is here ..... http://www.omegaowners.com/forum/YaBB.pl?num=1240077701  :y
Title: Re: alarm
Post by: babes99 on 25 October 2010, 16:13:41
Ok so why would this cause smoke within the car and not outside the car and why would this cause me to lose all the instrument illumination?
Andyb you said it may have taken something else with it on an earlier post any ideas as to what may have gone with it?
Title: Re: alarm
Post by: Kevin Wood on 25 October 2010, 16:29:55
Have you checked all the fuses are intact?
Whilst the power sounder can cause a fire and, unless recently replaced, is certainly better off out of the car than installed in it, if you had smoke from under the dash, then something under the dash was burning. This may or may not have been related to the power sounder (the wiring from it may have overheated) but it certainly merits an inspection of the wiring under the dash.
If a fuse has gone it's a good indication what circuit might have been at fault.
In any case, disconnecting the battery doesn't "reset" an Omega ECU in any sense. They have non-volatile memory.
Title: Re: alarm
Post by: babes99 on 25 October 2010, 18:45:02
Well in the meantime we have disconnected the battary mainly to cut the circuit of power incase it sparks off another fire. We have decided to pull that power sounder off the car we are going to do the dash tomorrow. I am starting to wish i had never bought the car  :-/
Title: Re: alarm
Post by: TheBoy on 25 October 2010, 18:50:39
Cannot access power sounder by removing dash....
Title: Re: alarm
Post by: babes99 on 25 October 2010, 20:08:25
I know it says that on an earlier post i have even been given the link on how to do that.
Does no-one ever read the threads from the beginning around here ;)
I need to remove the dash to see what else is burned out with it. I have no instrument illumination it has all gone. I also have a warning stating "Automatic gearbox" when i start the car up. It is also in "Limp home mode"
Title: Re: alarm
Post by: 24_Valve on 26 October 2010, 02:07:32
Babes play nicely ;)
TB (TheBoy) runs things round here  :y
Title: Re: alarm
Post by: Kneepad on 26 October 2010, 02:18:13
This could easily be misconstrued. I'm sure TB reads every word of the threads.
Any member who replies to your post is doing it in your best interest.    :y
Title: Re: alarm
Post by: babes99 on 31 October 2010, 17:37:01
Thank you everyone for your help and advice so far.
Update the car is now running without the power sounder unit. Now this doesn't appear to be what was on fire.
I have still got no instrument illumination?  :(
All fuses have been checked and are all intact. Any ideas?
Does anyone now if there would be a relay for this anywhere?
Title: Re: alarm
Post by: Andy H on 31 October 2010, 17:57:31
I don't know if this is relevant but I was once the passenger in an Astra when the ignition switch failed. A surprising amount of smoke quickly streamed out of the steering column shroud and up in front of the instruments.
I got the driver to switch it off quickly and the smoke stopped. The AA came and towed us to a garage where the switch was replaced.
I don't know if the Omega has separate circuits from the ignition switch for gearbox & dash :-/
Title: Re: alarm
Post by: Brikhead on 31 October 2010, 22:53:59
I'd say the smoke was either from the instrument cluster, the fuse box, or possibly (because of the timing of the smoke) the auto transmission module which lives in the same sort of area.
You'll only know when you start to investigate behind the dash...
Title: Re: alarm
Post by: babes99 on 01 November 2010, 17:09:16
Ok i have the auto box back working it is just the instruments that don't light up. I will ma\ybe get round to taking the dash out in the spring in better weather  :-/
