Omega Help Area => Omega General Help => Topic started by: tyreburner on 14 November 2010, 16:31:16
Hi guys and gals?
Long time since i been on here ( dont currently own a car as am driving coaches on tour so have no need for a car!)
BUT wor lasses s4 is off the road as some tosser pulled out into the side of us and caused her car to be written off as"uneconomical to repair"
Anyway we need a run around till she gets it fixed and i have found a 2.5 cdx for £300 but it is "running lumpy"??
Would like you guys to throw ideas of what it could be and cost if possible??
Thanks
Mick
Vacuum leak? a few pence for new hose
DIS pack/leads/plugs?
Cleverer people than me will help soon!
Usually some kind of air leak, or sticky ICV
thanks for the input - thats what i like about oof people are helpful :)
Am woried about h/g as long as noone mentions that i may just buy it!!!!!
HG on v6 is rare. Very rare. And its normally a coolant leak, rather than damaged firerings
if dis pack any idea on prices ? am totally out of touch?
Get a good 2nd hand one from a breaker on here. New for a Bosch part (not from dealer), probably iro £100
if thats the worst case scenario am considering it as once tinas finished with it its mine bwahhahahahaha ;D ;D
It could also be oil or water in the plug wells causing it to miss and run lumpy ;)
Would that mean h/g? :-/
The HG failing is really rare on the 2.5 V6.
Poor running could be the idle control valve (needs a good clean), HT leads (about £30 for a set but tricky to fit), DIS Pack (about £70 for Bosch OEM part from Ebay but again fiddly to fit), oil in the plug wells (caused by leaking cam cover gaskets).
Could just need a new set of spark plugs and an air filter or fuel filter.
Most problems with the Omega can be fixed on low budget as long as you provide the labour.
thanks i am now convinced but just gotta persuade her indoors to bite lol
want me to drop by and have a look at it ?
I'd take that offer if I wa thee.
hi am micks other half. Mick cant get online till tomorrow
nite (away workin) and he asked me to thank you for your offer.
I am gonna ring about the car in a bit, do you mean you
will come to look at the car with him, or look at it after we buy it. Either way we appreciate your offer :)
