Omega Help Area => Omega General Help => Topic started by: MartinP on 20 November 2010, 21:27:16
This relates to my Robin Hood kitcar build.
I have a 3.0ltr V6 that I have removed the power steering & air con units, I have installed a 45 Amp Bedford Rascal alternator where the steering pump was and now need a 690mm long aux belt.
How long is the non aircon aux belt?
Anyone got a industry book with measurements in?
Any info appreciated.
Martin
If you look at the part numbers on the belts they relate to the length in mm and the number of "poly-v" grooves.
.. So you'll be looking for a 6PK690 or similar (6 grooves, 690mm). There are a few different schemes. Halfords belts are of the form HB690g (g=6 grooves, etc). Bet to just go into Halfords and find the nearest belt to the size you want.
Thanks Kev,
local Halfords is only down the road :y
Martin
Sorted :y
went to the local Halfords, spent 20 minutes looking throught the drive belt guide, then went to the Omega page and the length I thought I was looking for turned out to be 1 metre to short :-[ :-[
Abandoned the search to return and check the length.
I needed 1680mm not 680mm :-[, different Halfords near work, 10 minutes of searching turned up a HB1675G belt which fits perfectly. :)
Martin
I did wonder. I know my Westfield has a 975 on it, and I can't see how you'd get round 3 ancillaries with a belt much shorter.
Glad it's sorted. One step closer. :y
