Omega Help Area => Omega General Help => Topic started by: mrjimbo on 23 November 2010, 12:02:28
What are the differences between mini facelift and facelift front leather seats and are they interchangeable ?
I know they will fit physically but is the seat heating side of things the same on mini facelift as on the facelift ?
facelift have a very different heationg system, with thermostat, with 5 settings.
Older a a simple on/off affair
Does that apply to mini facelift aswell. Mine i believe are mini facelift.
yes, the heaters are not compatible from pre or mini to facelift. afaik.
Cheers Jimbob, looks like mine need to be swapped for a pair from a Facelift then :-/
Is the thermostat and associated tiddlybobs integral to the seat?
In which case would it not be possible to fit 'old-fashioned' simple on/off heated seats to a facelift? Or indeed to fit 'modern-style' multi-temperature heated seats to a pre-facelift?
I know this could be a bit of a pain/fair amount of work, but finding good nick facelift leathers seats does seem to be a bit tricky, to say the least. Other than the multi-temp seats and active head restraints, they are to all intents and purposes, 'the same.'
