Omega Help Area => Omega General Help => Topic started by: Kneepad on 28 November 2010, 20:45:22
Why do we still call them nuts :D
One of the wheel bolts has cross threaded and I can't tighten it, does anyone know what size of Tap I will need to clean out the threads on the hub.
Its M12x1.5.
Lee
not off hand, but IIRC it's a metric fine. I've a bucket full of standard metric taps & I didn't have one that fitted. I'd to borrow one from a local garage when No 1 Son said he didn't use my windy gun to put his wheel back on his car.
Its M12x1.5.
Lee
Thanks for the speedy reply Lee :y
;D ;D ;D
Thanks Andy, if it's metric fine, then I'll also be out begging or borrowing.
;D ;D ;D
It's funny how you forget when you don't use them everyday. I can remember that tapping size for standard M12 is 10.2 mm which after I've Googled it .... http://www.efunda.com/designstandards/screws/screwm_coarse.cfm shows that M12 is 1.75mm pitch. As Lee pointed out, a wheel bolt is 1.5mm pitch, so it looks like you'll have to cap in hand tomorrow! ;) ;) ;)
having had a nother Google, you have a choice of 1.0 1.25 1.5 1.75 mm pitch M12 threads, I knew there were a few, but couldn't remember :y :y
http://www.engineeringtoolbox.com/metric-threads-d_777.html
Cheers Andy, thanks for taking the trouble, a couple of good reference sites there. Now bookmarked. :y
