Omega Help Area => Omega General Help => Topic started by: trem on 29 November 2010, 14:02:27
i have a problem with my auto box, i have the warning light on the dash after 10 mins of drivin, also the lights indicatin wat gear i am in jumps around and i no longer have use of the snow button. i haven't checked or changed the oil, but the box was fine until this morning when i got stuck in the snow, and revved it up to free myself. i dont have access to tech2 to read any codes.
Any ideas on what it could be.
Thanks
Trem
Thanks
Trem
Not the best weather for it but symptoms are synonymous with a dirty selector switch. http://www.omegaowners.com/forum/YaBB.pl?num=1267956397
can this be caused by say spinnin wheels in the snow, coz it has been perfect untill this morning when i got a little stuck. i have access to a dry garage if needs be to repair/clean it
any one else with any idea's, can selector switch just happen out the blue
Like any electrical switch it will fail when it's ready to. It doesn't need a reason.
Definitely symptoms of a failed switch.
can i repair it or does it need replacin, btw i am a maintenance engineer so can do most things
So click on the red link in my previous post then ;D
See the link above that RobG posted. The switch needs cleaning. :y
;D ;D ;D You beat me to it.
no bother lol, i will have a go at it his week lol, cheers lads
reet we have some good news, just finised puttin everythin back together, works a treat. the switch was like milkshake inside, cleaned up and re-fitted. just as pictures and description said.
Once again thank you for your help lads :) :) :) :) :) :) :) :) :) :y :y :y :y :y :y :y :y
Good result, well done. :y
