Omega Help Area => Omega General Help => Topic started by: raywilb on 02 December 2010, 21:29:10
Title: 1 more key prob
Post by: raywilb on 02 December 2010, 21:29:10
 overhaulliing ignition lock,.today i followed the instructions to the letter, laid each brass plungers out and made a note of the sequence. when i finished cleaning everything & i was satisfied when the key was inserted into the barrel it was OK. but the the key will not turn at all. any ideas why  :-/ :'(
Title: Re: 1 more key prob
Post by: Kneepad on 02 December 2010, 21:38:32
If i'm not mistaken, the key does not turn in the barrel. The key turns the barrel.
Did you put the barrel back where it came from to try it?
Post by: Abiton on 02 December 2010, 21:42:19
Did you inspect the inside of the bit on the left in this pic, and remove any burrs that may have been created by failed attempts to turn the key?
(http://images.omegaowners.com/images/guides/Ignition_Lock_recondition/IMG_7806.jpg)
Post by: raywilb on 02 December 2010, 21:43:38
i was toying with that idea, but then the stop pin could not be put in situ
Post by: Andy B on 02 December 2010, 21:44:54
sounds to me as though you have a/some tumbler(s) in wrong or wrong order.  :-/
Post by: raywilb on 02 December 2010, 22:52:36
i think they ,re right. i did make a note
Post by: markspark on 02 December 2010, 22:58:28
with the key inserted there should be no brass sticking out past the cylinder it should look like the above photo, if brass is sticking out you have mixed up the tumblers  :y
