Omega Help Area => Omega General Help => Topic started by: bigalan1971 on 05 December 2010, 20:24:33
Title: condensation build up when air con on mv6
Post by: bigalan1971 on 05 December 2010, 20:24:33
hi my air con is running funny it is not blowing out at all but fan is running .the only way to get the air to come out is if the recirculation button is pressed but this builds up condensation on the windows when i switch it back it makes a thud as if something is being shut off and no air heated air comes out please help does anyone know what the funk is wrong???? :( ::)
Title: Re: condensation build up when air con on mv6
Post by: markspark on 05 December 2010, 20:39:59
you pollen filter could be blocked  ::) not letting the air pass through it
Post by: bigalan1971 on 05 December 2010, 21:00:04
would this stop air con from blowing out air but with the fan still running ???it does work in re circulation mode . how is this possible???
Post by: markspark on 05 December 2010, 21:03:30
i dont think air recon goes through the filter
Post by: bigalan1971 on 05 December 2010, 21:04:53
where is pollen filter located and how do i get to it
Post by: Kneepad on 05 December 2010, 21:12:11
It's under the passenger side scuttle.   :y
Post by: feeutfo on 05 December 2010, 21:15:16
Polen filter is in the scuttle pas side. Open bonnet, plastic bit between windscreen and rubber seal between bonnet and bulkhead.
Pull seal off and the flap is under there by tax disc.
Try the re set. Press and hold auto and off simultaneously for a few seconds until the motors start buzzing. Some facelifts need the key in position 1 for this to work for some odd reason.
There is another reset for the re circ flap mentioned on tis, but can't remember what it is. The re circa flap gets fuddled and ends up in the wrong position iirc...? Someone will advise I'm sure.
Post by: bigalan1971 on 05 December 2010, 21:15:52
where the funk is that not to be rude but is that under the glove box??? ::)
Post by: feeutfo on 05 December 2010, 21:17:29
Or Please read the manual? Link in maintenance section. ;)
Or is it FAQ section?
Post by: bigalan1971 on 05 December 2010, 21:20:51
yes i think i understand it does seem like a fault of some sort just cant see it being pollen filter seems to easy . but will try both tomorrow it does seem just to be blocked had pollen filter change about a year ago :o
Post by: Kneepad on 05 December 2010, 21:21:31
2nd picture in this guide:
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
Try resetting first as Chris said.
