		Omega Help Area => Omega General Help => Topic started by: markspark on 08 December 2010, 18:39:43
				Hi all i have a 2.2 diesel and there is a noise that sounds like a fan or motor that is running in front of the drivers side wheel i can only hear it whaen the engine is not running but may it runs with the engine also. Today when i switched off the engine i could still hear it on looking at the car ther was smoke comming out infront of the drivers side front wheel (not water on brakes) what is the thing thats running also would this item cause the smoke??????
TIA  :y
				Diesel heater to prewarm coolant :y
				It's a diesel powered heater. It heats the coolant up when the outside temp. drops below a certain level.
				i had just done a 80mile Mway run should it still be running??
will it cause a problem it runs for a couple of mins when ive turned engine off ????
what is the smoke from ???
cheers for the warp speed reply  :y
				info is reading minus 5.5 here
Yes it will run for a while after you switch off, nothing to worry about.
The smoke if from the pre-heater exhaust, also nothing to be concerned about.
Most people are worried cause thiers don't work.
You are one of the lucky ones.   ;)
TIA  :y
 :o That must be incredibly annoying and it`s costing you loads of money to run...... :P
......I`ll take it off your hands and only charge a bit for removing it for you! ;D
 ;) I`ve been after one of those for my Disco.....they`re like Hen`s Teeth! 8-)
				lol thanks for the replies my mind is at rest now
what a fantastic place this is you learn something everytime you log on
cheers guys  :y :y
				if you want to remove it i will be more than happy to use it :P... it should not run for that long.. try to get a diagnostic, but i suspectthat his temp sensor is busted and does not recognise the temp of the engine cooling liquid
