		Omega Help Area => Omega General Help => Topic started by: Ploppy on 17 December 2010, 11:35:07
				Looks like the Alternator on my 3.2 Omega has died.
Ive looked at MarksDTM guide how to repair but cant find how to remove alternator / slacken belt etc on here.
Can anyone tell me how to do this please////
Regards
Ploppy  :'( :'( :y
				15mm (I think) on tensioner nut, turn clockwise to relieve tension then it`s
Multiram setup out.
Aux belt off.
Disconnect battery
Remove the two securing bolts (one end is torx, the other end hex)
swing the alternator out and disconnect the two rear electrical connections.
				(http://i190.photobucket.com/albums/z257/belisensis/OMEGAFORUM/V6AuxBeltRoute.jpg)
Multiram setup out.
Aux belt off.
Disconnect battery
pretty good is that !
the 15mm tensioner is the one labelled "T" ( funnily enough )
Multiram setup out.
Aux belt off.
Disconnect battery
 :P ;D
				Hi,
When you do get the alternator off, I am sure that with car being 3.2 L you will find a different type alternator to the version described in Marks DTM guide.
I expect you to find a Bosch XA 120 which will need regulator BR14-T3-V14
Basic idea is all fairly similar,but fitting regulator is not same.
Only place I know of where you can get regulator is Wood Auto. About £40.00 I think.
HTH
Roger
				Thanks all...
as always ... fantastic people on here !!
Regards
Ploppy :) :) :) :y :y
