Omega Help Area => Omega General Help => Topic started by: pauls on 19 October 2010, 00:15:34
Title: tyres
Post by: pauls on 19 October 2010, 00:15:34
Evening. Iam looking to change my tyres. I know everyone has their own favs but i have now tried several different makes and not to happy with any. Iam looking for ones that dont tramline,are road quite i dont know if it makes a diffence that i drive a estate
cheers
Title: Re: tyres
Post by: tango on 19 October 2010, 00:24:40
what size
Title: Re: tyres
Post by: pauls on 19 October 2010, 00:40:10
225 55 16 :y
Title: Re: tyres
Post by: dragonlord on 19 October 2010, 01:15:26
iv like the pirilie p6000 nice and sticky but dont were out to fast
tryed 2 p7000 on back this time same as but bit more road noise
not cheap but got a guy that seems to be able to get any tyer pre worn
that all seem to be hardly suffed and still got the littel rubber bits on somehow
at 25quid a corne i dont ask to many ? ;)
Title: Re: tyres
Post by: Shimmy on 19 October 2010, 01:34:32
I've just put a full set off rubber on in that size.
I went for the UniRoyal Rainsport 2's mainly because I buy tyres on how they perform in bad conditions, rain/standing water.  Have to say I'm very impressed so far, had a few outings in the last week in very heavy rain and standing water and it has felt very sure footed.  My biggest problem was visibility in the driving rain!  £80 a corner, but I feel they're worth it as tyres are something I don't like to skimp on.
In comparison my dad who was leading the way back home in convoy after buying a new motor had Nankangs on, and in the same conditions had a couple of moments where he aquaplaned in the heavy rain.  He's changing his tyres at the weekend.  :y
Title: Re: tyres
Post by: cem_devecioglu on 19 October 2010, 10:38:19
winter is in front of the door, if your area dont have frequent snow, and budget is ok go for continentals
or potenzas .. but if you want something grippy (for winter) goodyear ultragrip series are fine..
also for budget tires kumhos are ok..
Title: Re: tyres
Post by: Cliffo B on 19 October 2010, 11:34:36
For comfort and quietness I think you cant beat michelin primacy HP, but Oh dear when I went 18" my size are'nt made, just as well I suppose, the cost in the larger rim sizes made me gulp.I settled in the end for Goodyear Eagle F1 assymetric and found them to be quiet good,almost as good as my previous 17" michelins however the goodyears have a good rim protector and the michelins don't,so a bit of a bonus.
Title: Re: tyres
Post by: Kevin Wood on 19 October 2010, 11:41:21
I have used various Dunlops (SP2000, SportMAXX, etc.), SportContact 3s and Kumho KU31s and they work fine on the Omega.
The Sportcontacts are the quieter of the bunch, Dunlops a little noisy, KU31s in-between and the cheapest.
All offer a good level of grip in wet and dry. None have any tramlining issues on a well set up Omega however, they do get a little less directionally stable when worn to below 3 or 4 mm, I suspect because the tread becomes less compliant.
To counter this, I tend to rotate them to the rear when half worn and fit new rubber to the front.
If you can't get it to drive acceptably, don't ignore the possibility of a suspension setup issue or a failed wishbone bush or steering idler. Both are relatively common on an Omega.
Title: Re: tyres
Post by: majesticlarge on 19 October 2010, 12:41:49
I bought 2 Avon ZZ3
Features:
Ultra-high performance tyres for sport orientated cars.
Superb wet weather grip
Excellent dry roadholding
Very predictable on-the-limit handling characteristics
Gives you total confidence in driving your high performance car hard and fast
Rim flange protector to guard your expensive alloy wheels against kerbing damage
Wide range of fitments for most performance cars
Speed Index: ZR
Available Series: 30, 35, 40, 45, 50, 55, 60
there not the cheapest but i have an estate and i found them to be quite and they stick like glue to the road, my wheels never spin even in the wet. I got them from tyreshopper.co.uk
hope this helps :y
Title: Re: tyres
Post by: sport on 19 October 2010, 18:16:19
Hi i had tram-lining problems on my estate till i fitted good year F1 directional no problems since
Title: Re: tyres
Post by: feeutfo on 19 October 2010, 18:24:11
Wishbone bushes, rear donut bushes and tyres have the biggest affect on tram lining ime. Need to get these areas right on the omega. Can give you a deffinate avoid re tyres, Falkens, ESP 912. Terrable for tram lining.
Title: Re: tyres
Post by: Lizzie_Zoom on 19 October 2010, 19:05:51
I bought 2 Avon ZZ3
Features:
Speed Index: ZR
hope this helps :y
And for me, damn good tyres! :y :y :y
Title: Re: tyres
Post by: pauls on 21 October 2010, 00:21:31
Thanks for the advice ;D
Title: Re: tyres
Post by: tonyyeb on 20 December 2010, 16:16:43
My 3.0 Elite saloon tramlines quite unnervingly sometimes. It has Michelin Primacy's on 3 corners, but the right front is s budget brand with a completely different tread pattern.
Would this be the primary cause?
(Know it sounds like a daft question, but would still appreciate some feedback!)
At least i make you all laugh, eh?  [smiley=wink.gif]
Title: Re: tyres
Post by: Evo on 20 December 2010, 17:49:11
I have my doubts if the brand of tyre has an influence on tramlining & would suggest the primary cause is wear in the suspension.
I choose tyres on the Which test results (& price!). April 2009 gave the following overall scores:
Continental PremiumContact 2 69%, Michelin Primacy HP 68%, Uniroyal Rainsport 2 68%, Bridgestone ER300 67%, Nokian 2 G2 67%, Firestone T2300 66%.
Middling were Dunlop SP Sport 63%, Fulda 63%, Kumho 60%, Semperit SpeedLite 60%
Worst were Matador 55%, Hankook 52%, Avon ZV5 51% & Mabor 47%
The report gives detailed scores e.g. the Mabor were good for noise, economy, handling & grip but very poor at wet & dry braking.
Title: Re: tyres
Post by: msb1973 on 23 December 2010, 09:36:00
personally i'm a big fan of falken tyres, i had 452s on my 318bhp m3 and they were top notch, grip was exellent and the wear rate was very good as well, i used them on my local sprint track and some spirited driving on the road and after 12 months when the car was sold they still had a good 4mm tread left. I also had a set of 912s put on the partners old 1.6 astra, totally transformed it less tramlining and quieter and easily as grippy as the previous goodyears :)
Title: Re: tyres
Post by: feeutfo on 23 December 2010, 11:39:14
Please be aware, what works on one vehicle will not necessarily work on another. Falkens being one in particular, there are members here that have them on other cars, and then fitted them to the omega with very different results. On the omega straight line stability is the handling key.
Falkens are exceptionally quiet though, but on this car that's where the good news ends.
But for the op. I would concentrate your efforts on worn chassis components and set up. Then worry about tyres tbh. Reason being if there is a fault on the car, the tyres will soon degrade to the same level and your back to square one, no matter what's fitted.
Title: Re: tyres
Post by: cem_devecioglu on 23 December 2010, 13:50:22
some brands have more tendency, however as width increases you will definitely have!
Title: Re: tyres
Post by: feeutfo on 23 December 2010, 14:00:30
...also that info gives no clue as to the test car involved. Front wheel drive or rear, big small, light heavy?
Title: Re: tyres
Post by: cleggy on 23 December 2010, 14:55:13
On my estate Avon ZV5's are an excellent tyre, quiet, good grip, no problems. I think I paid £300 +,  for the four fitted.
Title: Re: tyres
Post by: msb1973 on 23 December 2010, 16:01:53
Sorry but i have to dissagree with your comments about falken tyres as i have used them on a few vehicles and know of alot of others using them on a wide range of vehicles and not one has had any problems with them, infact all feedbacks been very positive, most people overlook falkens/toyo's etc as they are alot cheaper but tbh its mostly snobbery imo, i know where my moneys going when it comes to replace tyres :)
but you are right in saying if there are other underlying problems it wont matter what tyres you have the handling problems will still be the same :y
Title: Re: tyres
Post by: feeutfo on 23 December 2010, 18:26:12
Yes I had a feeling you would  ;D
Fire away, but don't say you where not warned... :y
But clearly you 've not tried them on the omega, so impressive confidence  levels there:-X
Just to be clear, the worst possible combination is the 912 on a 17" wheel, the 452 is not as bad in that size. Then in the smaller wheel sizes the symptoms are less pronounced again on a 16". So if you must fit falkens fit the 452 to a 16" rim.
Edit, in my case on a 17" rim.....
To begin with they won't feel too bad, in fact when new they are so quiet the it will give the illusion that a massive improvement has been made. But actually the improvement in handling will be only marginally better than the worn put shagged tyres that just came off, so you'll think all is well to start with.
Then after about 4k you'll find the tram lining creeps in, after 7k start looking for faults on the car, after 10k post up on here asking for desperate help as the car is almost impossible to keep in a straight line. Other kind members on here offer to swap wheels having driven it to declare the thing "definitely not right" and " that cars flecking dangerous,I ain't driving that again"...!  on a single carriage way the car had a built in speed limit of 50mph as it simply would not stay between the white line and the verge, any faster and the driver could not react quick enough to keep it out of the ditch/on coming traffic.
These tyres are absolutely appalling on the omega and quite easily lead to a dangerous condition. Now if you want to disagree with the facts as laid out and witnessed by two other highly respected admins on here, then be my guest, but be advised, with other wheels shod with two other makes Dunlop where fitted to the front of the car, half the symptoms disappeared. That was enough for me to bin them with another 5k worth of tread still to use in favour of sports contact 3's. From that point on all problems disappeared instantly. It was a delight to drive. But then it would be, new unworn tyres where now fitted with a nice flat profile, they WILL handle better new, but the real proof was that the sc3's never degraded to the level falkens felt like from new.
So fire away as said, fit falkens, just post up on here where and when your driving your car so we can all clear the area. Shite stability, shite grip on the 912 and poor wear to boot. But they are quiet  ;D :y
Title: Re: tyres
Post by: TheBoy on 24 December 2010, 11:49:22
We all expect different things from our tyres, we all have different priority and demands.
Then, as chrisgixer pointed out, different car models react well/poorly to some tyres - I use P6000s on the Rover, and they are utterly fantastic on that, but I wouldn't normally fit that junk to a wheelbarrow.
This makes it very hard to recommend a tyre, even if you have actually tried a specific tyre on that car model.
I am currently in a dilema, as I've been having myself too much fun on my Dunlop SP9000s, and have boolaxed them. Without hesitation, for my 235/45ZR17, I would buy another set of SP9000. For my needs, they are nearly perfect (let down by road noise, and a bit of tramlining when very worn). Astonishing grip levels, wet or dry, for both cornering and stopping, and reasonable durability.
But SP9000 are not available any more. And I've never found another tyre I am completely happy with to replace them.  One tyre that will not be going on is Falken 912.  Having swapped my SP9000 for chrisgixers 912s in order to pinpoint his stability issues, and turning my normally very predictable MV6 into 1.7 tonnes of unpredictable, dangerous junk, I would class 912s on the LSC Omega as lethal in the dry (no idea in the wet).
I did try a set of Avon ZZ3s on my old 2.5TD Omega. There didn't work at all on that car. Fortunately, it chewed them to shreds in 4k, so I didn't have to suffer them for too long ::).  I put some cheapo budgets on it - Nexen 3000. They were pretty good, though like most budget tyres, tend to tail off in very wet conditions.  Not sure I'd want them dealing with the extra power of the MV6 though.
My Elite has my pet hates on - Michelin PS3.  Possibly one reason I rarely drive that car.
Title: Re: tyres
Post by: TheBoy on 24 December 2010, 11:55:18
So I'm currently torn between Dunlop SportMAXX (as the natural successor to SP9000) or the budget Kuhmo KU31 (due to price/performance ratio), with Conti SC3 as an outsider (I've used SC3s before on the MV6 (and SC2s, that I thought were better)), but too pricey.
Or do something completely daft, and stick on the likes of Michelin PS3, knowing that they will possibly outlive the car (and me if I do not adjust my driving style to suit).
Or something else.
Title: Re: tyres
Post by: Boatboy on 24 December 2010, 12:00:51
Afraid this echoes my experience to a T, albeit on 15" wheels. Rears 7k, front 6k. On a recent trip on a dark and twisty A road in the rain with oe faded (ie v dull) headlights my wife was getting concerned for my health as my driving was so erratic.
A new track rod end (mot failure) means I seem to get better feedback from the corrective input so the veering from side to side is reduced, but the tramlining is still there. Touch wood not needed the brakes in anger for a long while, but the tc gets a good workout on wet roads.
The real pooh for me was they were recommended by none other than a certain geometry specialist in Chesham. If anyone has his ear maybe they could put him right.
In the meantime I'll be taking it easy.
Steve
Title: Re: tyres
Post by: TheBoy on 24 December 2010, 12:14:58
Although they know the Omega for geometry, its harder (impossible?) for them to know how specific tyres react on a car.  It would appear from reviews, and other people's experience of them on other cars, that the Falken 912s and 452s in particular are very well respected on many performance cars.
As I said earlier, we all have different demands of our tyres, so that further clouds any ability to recommend.
I am due to visit said geometry specialist next week, so I will mention that Falken 912s aren't an ideal choice for many on the Omega.
Title: Re: tyres
Post by: feeutfo on 24 December 2010, 12:19:33
Steve
Oh don't worry, he knows about the aggro with my old car and falkens. That car must have been on his set up ramp more than any other in history trying to sort it out. Only thing that made any odds was binning the 912's.
I would suggest a call to him though, save anybody else going through the same nightmare with an omega. In fact tell remind him about my car while your their, and if he is at all sceptical I'll meet you there and we can fit my wheels to your car and he can test drive the differance...
...or your wheels to mine, whatever.
